Author Topic: Injector question, what is...  (Read 1612 times)
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: Injector question, what is...
« Reply #10 on: 21 August 2007, 23:57 »
Yipee.
does 035 133 554  - ''insert for injector'' £1.41 sound right to people?
Offline monzablue16v
« Reply #11 on: 22 August 2007, 00:27 »
Thats the one matey :)
Offline Chris-White
« Reply #12 on: 22 August 2007, 00:29 »
Trip to the stealers tommorow then, cheers boss!
Offline kkh120
« Reply #13 on: 22 August 2007, 09:14 »
Did this job a while back and ran into the same problem. I think you need a 13mm hex to remove the brass insert. I only had a 12mm one to hand so beefed it out with loads of cellotape to see if that would work (needed it fixed that night).....did ok! :laugh:
Mk2 8v and 16v.
Always looking for bits!
Offline Chris-White
« Reply #14 on: 23 August 2007, 21:29 »
Now im really confused.
bought both the brass insert, the seal and the plastic one from VW.
Pulled the injector out with a bit of a struggle, and the unscrewed the old brass bit with a 12mm (which was an effort). The old plastic then dropped out in an engine bay direction. It had NO seal on it.
So i put the new seal onto the plastic thingy, its was a rap fit and wont sit flat at all, its just too big. I then pushed this through the hole in the inlet manifold. Then i screwed on the new brass bit until it went tight and my 12mm allen bit slipped (fcuking the brass). it sits far higher than the other ones, and the plastic sits a bit lower? I then tried pushing the injector through and it wont go for sh!t. I looked down and the seal looks like its stopping it. then, the plastic fell right through????
Does the injector hold the plastic in place or something, i really dont get it. Oh, and the brass bit is firmly stuck in place.
what the hactual f**kuk is going on?
