Author Topic: Dolly - £500 MK2  (Read 16632 times)
Offline jv
  • Administrator
Dolly - £500 MK2
« on: 13 August 2007, 13:08 »
« Last Edit: 02 November 2008, 15:20 by jv »
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Dolly
Re: Dolly - £500 MK2
« Reply #1 on: 13 August 2007, 19:06 »
Cheers Admin guy..
Right guys and girlies i owned a mk2 Golf 1.6 Driver a year or so ago had every problem you can imgaine and fixed 95% of it, worst thing i did was sell it.. so now i have the money to run 2 cars i thought time for another..Much searching for the cheapest ok condition 3 door i could find i win this on Ebay:
1990 H Reg 8v GTi
Big bumpers
G60 Arches
Fog Lamps
C/Locking
PAS
16" Team Dynamic alloys
What appears to be cheap lowering kit 40mm possibly.
Jetex S/S middle to Rear section
Im going for the clean original look, the interior is really excellent condition so i dont need to mess with that, some BBS alloys and some FK coilovers for look im after and generally clean the engine bay up as you can see the engine wiring has been chopped stuck together with red electrical tape, connectors are broken so im sorting that out, It needs a PAS steering rack as its leaking really bad on my moms drive  :grin: , the H/brake is really poor but ive just orderd some mk4 Callipers for the rear, the in time a 4 branch manifold matched to a complete Exhaust S/S possibly miltek.
Will update as jobs are done :)
Offline Dolly
« Reply #2 on: 08 October 2007, 14:04 »
Well little to report at the moment.. i currently have a 325i bmw im moving to fund the G60 lump so need to get that shifted then let it begin!
Have done a few minor things ..
German pressed metal REG plates
removed the wiper arms and sprayed black as they was a little rusty and paint was flaking
Had to replace the N/S/R 16v light as someone tapped it to try and make my side light burst into life, all they did was crack the lense  :cry:
purchased a steering rack as if you read above its shagged and leaking oil everywhere, i got it on ebay with all pipes, resoviour, pump, pulleys, even the belts . so im likely to have a PAS Pump and Crank Pulley for sale shortly. i have decided to fit the rack when i swop engine, im guessing it might make it easier!? so shortly before ill take it for proffesional recon.
Pics taken earlier today showing off the new reg plates.
Rack ..
Offline Dolly
« Reply #3 on: 08 October 2007, 14:06 »
forgot to add, when i took the rear reg plate off, i discoverd the tail gate is worse than it looks. the retainers for the number plate screws have fallen out because of the rust hole, and the grab strip one of the retainers for the screws has done the same, so im hoping it doesnt completly fall apart during the winter, then either find another ok one, or remove mine get it done, and smooth the wiper out .
Offline Dolly
« Reply #4 on: 17 February 2008, 17:47 »
right ho. this has turned into the mk2 G60 thread after i took the plunge late last year and bought a G60 engine/box/loom.
As far as im aware the charger is a stage 4, has a smaller pulley and a chip in the ECU all thanks to jabbasport. Today i finally decided to do something and removed a few things so i can clean them up ect:
Charger
Charger brackets
Alternator
Rocker Cover
Inlet manifold
So the plan, ( sell the bmw ! ) clean all the engine and its part probably going matt black with a clean charger and rocker cover. replace gaskets, timing belt bolts ect.
Samco cooling hoses
Samco boost hoses
a Rallye outlet
FMIC
Top fill Rad
Get an exhaust that isnt going to melt my car
If i can get some 16v hubs then ill also try and get 280mm brakes on the front, and then im thinking ronal turbos.
Offline Dolly
« Reply #5 on: 25 February 2008, 16:52 »
ccouple of things coming together now, Coilovers for the stance
and a TSR 4 branch manifold for the G60, heat wrap and it should be good
Offline Dolly
« Reply #6 on: 21 March 2008, 21:28 »
Got My ass in Gear and things happening today ( good friday ) and a few smaller things happning earlier in the week, ie collecting parts, cleaning and paint parts:
DONE
Clean and paint charger brackets
Clean and paint intake manifold
Clean and paint rocker cover
Remove 8v Gti engine
Removed Dash ready for matrix replacment tomorrow
Removed a poxy aftermarket alarm/immboliser
removed subframe, and steering rack
removed control arms
removed suspension ( front )
TO DO
Fit G60 engine and gearbox, clutch and flywheel
Fit G60 engine wiring loom
G60 coolant and intake systems including standard Rado Intercooler
New control arms
A newish Rack
Coilovers
Mk3 Heater matrix and refit dash
Mk4 Rear callipers and braided hoses
Offline Dolly
« Reply #7 on: 21 March 2008, 21:29 »
Offline Dolly
« Reply #8 on: 28 March 2008, 09:37 »
better pics, got it in and running  :grin:
Offline Dolly
« Reply #9 on: 17 May 2008, 20:43 »
Latest, fitted the G60 front brakes, well waiting for the pads, but changed the hubs discs ect. Also got the Rad recon'd as it was looking a little tired, took this oportunitly to change the top rad outlet pipe and gasket, which are still available from VW.
Also 1.3 speedo cable now fitted.
