Author Topic: 17cm Components  (Read 2432 times)
Offline Alpine 8v
17cm Components
« on: 12 August 2007, 16:52 »
I'm thinking of buying the following amp to power a front component set up (17cm) in door pods
Alpine PDX-2.150 with the spec from the web site below
SPK Connect
4Layer Glass Epoxy PC Board
Class-D
Layered Installation
1/2 Channel Operation
Thermal Management Processor
Adjustable Crossover (HP/LP)
MOSFET Power Supply
DC-DC PWM Power Supply
MOSFET Final Outputs
STAR Circuitry
Auto Over-Current Protection
Top Mounted Blue LED Power/Status Indicator
Integrated Wire and Mounting Screw Terminals
One Side Terminal Layout
Gold Plated RCA Input Connectors
Continuously Adjustable Gain Control
Gold Plated Power Screw Terminals
Dimensions: 257mm x 192mm x 62mm
RMS Power
[2ohms @14.4V 1%THD]: 150W x 2
[4ohms @14.4V 1%THD]: 150W x 2
Bass Engine® Sound Tuning
Crossover Frequency Adjustment
Could anyone recommend some decent components that would match the amp power wise?  Alternatively another other amp/speaker combinations that sound good together.
thanks
Offline tommk3cab
Re: 17cm Components
« Reply #1 on: 13 August 2007, 22:21 »
basically take your pick from these pages, make sure they are around 150w rms and you cant go wrong.
http://caraudiosecurity.com/shop/product_list/c_path/60_61_109/spd/17cm---6-5-components/pg/2.html
personally I would go for these, depending on budget. you will need to be a bit careful with the amp gains with this set though, because they can only handle 100wrms and the alpine amp is 150wrms.
http://caraudiosecurity.com/shop/product/products_id/6724.html
and with most componants you will need to think about their physical depth.
« Last Edit: 13 August 2007, 22:28 by tommk3cab »
