Author Topic: Oil in distributor cap - help  (Read 2057 times)
Offline vwgolf16cl
« on: 22 February 2004, 16:01 »
 :o
I own a 1994 VW Golf CL 1.6 and was suffering from the car cutting out (total loss of power, rev counter 0, alternator and oil light on) at random intervals but after the car comes to a stand still it starts again straight away.
Since the car was due to have a service I thought I?d let a VW dealer find the problem (?47 for half an hour labour!!!) and fix it for me.  Apparently no error codes were found when they hooked the car to a computer but was told the throttle body needed cleaning (?90) and my distributor cap and rotor arm was worn and needed replacing (?65).
I later went to a garage (Bosh service specialist) who managed to clean the throttle body for a lot less then ?90. After the throttle body was cleaned the car has not cut out since (over 2 weeks now!).
I bought my self a distributor cap, rotor arm and a set of HT leads which I thought I could fit my self.  However when I took distributor cap off there seem to be traces of oil around the inside edge of the cap.  Silly question?is this normal and does it seem I may have a big problem on my hands now??? Any advice is welcome...
Offline jedi16v
Re:Oil in distributor cap - help
« Reply #1 on: 22 February 2004, 16:13 »
sounds like an oil seal gone on dizzy. shouldnt be to hard to fix
Offline Ciaran
« Reply #2 on: 24 February 2004, 09:37 »
well i had this on mine about 2 weeks ago and turned out i needed a new distributor lovely ?150 down the drain for part and fitting
golfvr6
« Reply #3 on: 24 February 2004, 10:37 »
You can change the seal in the distributor, send richandhazel a pm, he knows i think.
