Golf mk2
2 2 4 lamp conversion beams???
Topic: 2 2 4 lamp conversion beams??? (Read 650 times)
gazzij
Just got here
20 July 2007, 11:44 »
how do i convert it so my full beams work whn i change from a 4 to a 2 lamp? do i just need a different set of lamps or will i need to change sum of the wiring? cheers gaz
JMallows
Re: 2 2 4 lamp conversion beams???
20 July 2007, 12:17 »
Just remove the spot lightrs, and tape the extra wiring from them back into the loom somewhere. I wouldnt cut them off, incase you want to go back. You will need a new grille though
A clever person solves a problem. A wise person avoids it.
gazzij
Just got here
20 July 2007, 12:26 »
so how do my beams work? as i thought that is i unplug thm n tie thm up sumwher like u av suggestd thn i wont av any full beams?
Gambit
Forum addict
20 July 2007, 12:27 »
the outer lights have main beams included. the inner lamps are simply spot lamps
Golf mk2
