Author Topic: evil first gear  (Read 6613 times)
Offline tall pete
Re:evil first gear
« Reply #10 on: 20 February 2004, 12:20 »
Yeah, something nuts about Corsas
Heh heh.
Peter.
Speedydub
Re:evil first gear
« Reply #11 on: 20 February 2004, 12:57 »
Both of mine dont like first gear unless they are stationary, or near to it.
Offline Golfgal
Re:evil first gear
« Reply #12 on: 20 February 2004, 13:08 »
Gettin in ne gear would be a plus  :D
Must get her sorted but I'm use to it now. Makes it funny wen I get in2 the mk2 he he!!
V5 Beetle owner. I'm just here for the misfire threads....
Dinky
Re:evil first gear
« Reply #13 on: 20 February 2004, 23:10 »
Quote
did nobody actually bother to read what i said then??
Yes,a fail safe,but everyones just sayin that it happens to them.Plus mine doesn happen wen i go form 4th to 1st,cos i daint do that,i'm talkin about wen approachin a roundabout,slowing down,dropping from say fourth to second,then tryin to get it into first wen i hav to stop.
As for the clutch not disengagin properly,happens on my b/fs escort,only the car starts to judder,until u put the car in neutral-is that wht happens to urs?,cos thats not wht happens to mine! :-\
Dinky  :-*
Offline ashmk1
Re:evil first gear
« Reply #14 on: 21 February 2004, 15:21 »
INFO FOR BOYISH RACERS 8)
The real cause is bent selector forks.  These are damaged when people
try to force the gearbox into 1st gear before it's ready to go... This
excessive force bends the selector forks and causes it to be out of alignment.
The gearbox has to be stripped down to repair and is therefore expensive.
Don't force your gearbox into first at higher revs.  Not only do you risk
causing this problem, you also cause excessive wear of the Synchromesh.
Learn to double clutch, or rev the engine before engaging first to match
(synchronise) the gear speed.
If you have a damaged gearbox there are a few tricks to let you live with this
problem until your ready to repair it, when the rest of the gearbox is worn out
or you have the funds for repair.
The best way is to select first gear just before you come to a stop,
just before your wheels stop turning.  What's happening here?, The gears and
synchromesh are still turning and even with bent selector forks, the gearbox
will line up the gears, while it's turning, so it will slip straight into 1st.  If
you allow the car to stop before you select 1st, then there's only a 20 percent
chance the gears will be lined up.  This is why when you let the clutch out again,
or select another gear before putting it into first, it sometimes helps it go into
gear.  Of course, it means you have to keep the clutch in while waiting at the
lights, otherwise you have to put the clutch in a few times until it synchronises.
@sh
mk1 gti16v cab & sweet gearbox ;D
Offline bigkev750
Re:evil first gear
« Reply #15 on: 22 February 2004, 13:16 »
put in fully synthetic oil in mine and seems a lot better a cheap and effective mod :)
Blue MK2
Re:evil first gear
« Reply #16 on: 22 February 2004, 13:41 »
whats double clutch exactly? ::)
(not a boy racer)
Offline ashmk1
Re:evil first gear
« Reply #17 on: 22 February 2004, 14:27 »
double clutching is when you change gears (downshifting) in two stages rather than one.
Instead of putting the clutch in, shifting, and letting it out again you:
* Clutch in, shift to neutral, clutch out
* Blip the throttle to rev to the rpm the engine will be doing in the gear you're about to change to
* clutch in again
* Shift to the gear you want
* clutch out
Blue MK2
Re:evil first gear
« Reply #18 on: 22 February 2004, 15:22 »
ill probably loose a race trying to remember al that ::)
Offline Cupra Turbo
Re:evil first gear
« Reply #19 on: 22 February 2004, 22:26 »
Double Clutching actually does a few things
1: Makes ya clutch/gearbox last longer
2: Makes U drive faster
3: Makes U concentrate lol....
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=38
Modified Golf GTI, 130Bhp(est), All Smoked Plus Quad Headl
