Author Topic: Tracking/awful handling in the wet.  (Read 1926 times)
Offline Dougie_91 8v GTi
  • Driving has never been such fun!
Re: Tracking/awful handling in the wet.
« Reply #10 on: 17 July 2007, 21:41 »
Thanks for all the suggestions, :smiley: interesting to see that others have similar issues!  Yes the car does have power steering, and I am sure that the belt as well as the fluid may need changing.  There is for some reason slight hesitation/resistance sometimes at low speed/stationary when turning the wheel to the left, will see how this develops after changing the belt and fluids.  I will check out the steering wheel nut, and will have to look into how to realign the steering wheel so it sits straight at 12.00.
I may also get the rear wheels balanced, although the guy at kwikfit said this may affect the tracking?  Is this true or not?  Still concerned about the nervousness at speed, braked for the lights this evening from speed and turned the wheel a faction whilst moving lanes, and was sure the car dipped or felt uneasy on the front right wheel (almost felt half as wide?), will try the same move again tomorrow to be more specific!  All nuts tight, tread good and inflated as recommended, so?????
With regard to bushes etc, the front should have been commented on by kiwkfit if deemed in need of attention, the rear is something I am keen to have them look at and comment on.  Will keep you posted. regards.
Dougie.  :smiley:
Offline kittie
« Reply #11 on: 18 July 2007, 12:35 »
Really need to get mine sorted, fed up of having a car that feels funny in a straight line and amazing going round a bend!!!
Offline boneybradley
  • Back in a Mk3...
« Reply #12 on: 18 July 2007, 12:50 »
my mk3 handles similar..twitchy at high speeds and when wet and that's with new bushes,shocks and spring's.... The only time it does ok is with perfect tyre pressure's. I will be keeping a looky on this thread for idea's
Offline 8vreturn
« Reply #13 on: 21 July 2007, 08:30 »
I had my 8v tracked on Wednesday.  The people who did it in Stamford (Kingsway) managed to do it after much use of gas and phone calls.  With my motor not having power steering only one track rod is adjustable on the car and them not having settings for Mk2 there was a lot of head scratching.  I ended up with my steering wheel at 11:50 but after re-seating the wheel it is fine.  However I need to search for advice on camber as after lowering the car I'm not sure what the camber should be.  When I re assembled the front end I pulled the wheel out at the top to compensate for the change in geometry.  The last time I did this and pushed the top of the wheel in there was too much camber - think of Beetles which have been slammed.
Rich
Offline 8vRicey
  • Silver Mettalic 8v GTI
« Reply #14 on: 21 July 2007, 09:23 »
Rich
VW do some smaller shanked bolts for just this purpose. I think it's negative 1.25 - 1.50 degrees camber, tracked straight ahead.
Do a search, there is loads on it.  :wink:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
