Author Topic: Which order?  (Read 38116 times)
Offline Rhyso
Re: Which order?
« Reply #20 on: 30 July 2007, 12:03 »
gutted!  :cry:
it normally rains after i wash my car but its been nearly 24 hours and no sign of any.......  :huh:
Offline Ridg
  • TDI - Soot Happens!
Re: Which order?
« Reply #21 on: 20 August 2007, 13:21 »
what about jet washers?
the other problem with jet washers is that they are going to strip and wax / protectants you've already got on.
most shampoos are designed to leave them on, obviously claying, polishing and cleaner waxes will remove wax also.
if you want to work from the base up then a jet spray is fine, but like rhyso says, f you come straight on you risk embedding dirt into the paint.  jet washers are good for foaming, under car and arches though.
Offline rowlers
  • I'm back - MK7 GTI
Re: Which order?
« Reply #22 on: 22 August 2007, 15:25 »
just done the MER. No time now tho to put the wax on.
So can I leave it until tomorrow and gfo straight to the wax?
Offline Ridg
Re: Which order?
« Reply #23 on: 22 August 2007, 15:32 »
yeah you might want to QD first otherwise you could be waxing a dirty surface
Offline rowlers
Re: Which order?
« Reply #24 on: 22 August 2007, 17:52 »
aha! I'm getting the hang of this now!
cheers all!
Offline rowlers
Re: Which order?
« Reply #25 on: 09 September 2007, 20:41 »
I've got 2 coats of wax on now and am not that impressed tbh.
What am doing wrong?
washed with megs gc wash.
polished with mer.
waxed with megs gc liquid wax.
is this wrong? have I missed something out?
cheers
Offline Ridg
Re: Which order?
« Reply #26 on: 09 September 2007, 22:14 »
what aren't you impressed with, the shine the beading or something else?
if its the shine then you could try another polish, i personally don't think that mer is that good.  i currently use megs stage 2 polish, if you want a further shine then you can use a glaze (with wax on top)
Also i'm not really a fan off waxes that come in a bottle and prefer pure waxes that you get in a tub i use, collinite 476s followed by collinite Marque D'Elegance (No. 915)
what colour car do you have
Offline rowlers
Re: Which order?
« Reply #27 on: 10 September 2007, 20:32 »
the shine is no better with the wax than just the MER. The shine is there but maybe I was expecting more!?!?
Is the water supposed to run off, or stand on the paint?
It just stands on mine?
I'll maybe try a glaze and also fancy a sealent as well - can you recommend one?
PS the Quick detailer I'm liking alot :smiley: :smiley:
Offline Rhyso
Re: Which order?
« Reply #28 on: 10 September 2007, 20:40 »
if done properly the water will 'bead' as in produce tiny droplets before eventually running off.  its quite cool to watch.
what colour car you got?
Offline Ridg
Re: Which order?
« Reply #29 on: 10 September 2007, 20:52 »
like rhyso says the water should bead like in this video
if you want proper beading then you really need to use a pure wax and not the stuff that comes in a bottle
