Author Topic: How long will it take for a garage to ....?  (Read 2007 times)
Offline 8vRicey
  • Silver Mettalic 8v GTI
« on: 03 July 2007, 16:06 »
How long will it take a garage to change rear discs and pads, and rear axle bushes ??
Been quoted 6-8 hours, but will only charge me 6 hours (£150), if it takes less then obviously he will charge me the hourly rate.
Labour only, i supply the parts.
Does this seem about right ??  :huh:
« Last Edit: 03 July 2007, 16:11 by 8vRicey »
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
Offline ...joe
Re: How long will it take for a garage to ....?
« Reply #1 on: 03 July 2007, 16:57 »
its probably not too far off, the rear beam can be a right bastard. i had to get alot of heat and an air gun to get one of my bolts undone. then depending on whether they have the right press could mean it takes a while to get the new bushes in. £150 is pretty reasonable for the effort.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline nealey
« Reply #2 on: 03 July 2007, 19:17 »
The most time consuming job is the axle bushes, if you can get everything done for a definate price of 150 then i personally would go for it
Offline paultownsend
« Reply #3 on: 04 July 2007, 00:55 »
a local garage/vw enthusiast did both my rear beam bushes in less than 2 hours. i stayed in the garage with him as we were also talking about an engine conversion.
give everything a good dose of wd40 everyday for a few days before to help the mechanic out
he drilled out the old bushes with the rear beam dropped but still attatched by the rear strutts
and trust me, please trust me. Get powerflex rear bushes
Offline bomp
« Reply #4 on: 04 July 2007, 01:11 »
I reckon it's a brilliant price, (only because I changed my own, with VAG bushes, and it was a cow of a job) but I got rid of 16 years worth of rust aswell with a drum sander and Hamerite, so it took me a week to do.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline ...joe
« Reply #5 on: 04 July 2007, 12:26 »
sorry i disagree with that, poly bushes make it too stiff on the rear and can make it a bit sketchy in the wet. genuine bushes have an amount of passive rear steer built in which help cornering.
Offline Agreeable Slick
  • Unit
« Reply #6 on: 04 July 2007, 12:35 »
I would agree, there is a certain amount of stiffness you can place into the rear beam, but bushes do tend to make it a little to stiff, mine would skip and jump all over the place in the wet with my old set up, so i had to take some things off to calm it down a little.
« Reply #7 on: 05 July 2007, 00:07 »
personal opinion. iv never had any problems
full powerflex
eibach springs
oe boge shocks
h+r roll bars
= an amazing handling car in around the country roads i live, in the dry
i dont even think about going fast in the wet, in any car
Offline Simon8v91
« Reply #8 on: 05 July 2007, 09:33 »
Going to have a go at mine after my hols.  I was hoping to get away with not totally removing the rear beam.  :smiley:
Offline ...joe
« Reply #9 on: 05 July 2007, 10:16 »
^^ i got a spare rear beam, got it powder coated, built it all up with new brake lines, brakes, bushes etc off the car and swapped them over. still was a cow getting the old one off.
