Author Topic: Handling problems  (Read 2034 times)
Offline bomp
Re: Handling problems
« Reply #10 on: 24 June 2007, 17:23 »
Haha, if your steering wheel is on the right hand side, then it's right hand drive.
Get under the car and have a look up behind the subframe (where your feet would usually be when driving) you'll see it easily enough.
« Last Edit: 24 June 2007, 17:30 by bomp »
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline rowlers
  • I'm back - MK7 GTI
« Reply #11 on: 24 June 2007, 17:26 »
nooooo, is it ZF or TRW?? whatever they are!!!
Offline bomp
« Reply #12 on: 24 June 2007, 17:34 »
Is yours power assisted? You should be able to tell from the pics if it's ZF or TWR.
Offline rowlers
« Reply #13 on: 24 June 2007, 17:44 »
yeh pas, I'll av a look at some point!
Offline herbster
« Reply #14 on: 24 June 2007, 18:16 »
Are your top mounts ok, they can cause a bit of wandering, have you checked your springs, sounds daft maybe but the obvious is sometimes the last we check!  :laugh: If the mounts are worn out a bit the nut and washer will be protruding upwards a bit and the rubber will be badly cracked, the springs may only be worn one side, maybe the shocker!  :rolleyes:
FAB is my life and the CABRIO's the wifes!!!!
Offline rowlers
« Reply #15 on: 24 June 2007, 18:49 »
no all new in last 12 months.
I'll see what its like on way to work - 30 miles should give me a good feeling on the new 'bones!
Offline cняis
« Reply #16 on: 24 June 2007, 19:11 »
funnily enough, mine is suffering from exactly the same problem after the garage replaced a front wheel bearing... i bet they were heavy-handed and knocked the camber/tracking out, as the car pulls to the left and wanders slightly. they have agreed to sort it free though  :smiley:
