Author Topic: My new Edition 30  (Read 6835 times)
Offline p3eps
Re: My new Edition 30
« Reply #20 on: 21 June 2007, 22:09 »
In my previous GTi, I had an Alpine headunit with iPod adapter. Drilled a small hole in the side of the glovebox, fed the lead through into the glovebox to the iPod. The iPod itself was in a slip case with a couple of small velcro patches on the back. Two matching patches on the "floor" of the glovebox kept everything secure, and prevented the iPod from sliding around.
I was thinking about maybe going for the cubby under the light switch?  We use Peli cases at work alot - which come with 'pick and pluck' foam that you can make any size you want!  I could fill it with foam and cut out the shape of the iPod in it... then it wouldnt move anywhere!
I have 2 30gb ipods here.  I used to be an Apple technician - so I made a couple of good ones out of various broken bits!  I will just keep one dedicated for the car  :cool:
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline AlanH
« Reply #21 on: 21 June 2007, 22:13 »
For me, the glovebox option kept the iPod out of sight and out of mind. Where are you going to mount your iPhone when you get it :grin:
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline p3eps
« Reply #22 on: 21 June 2007, 22:23 »
The cubby under the light switch is out of sight too!  It will fold out when I want to take the iPod away.
I'd be scared putting it in the glove box as its pretty big, and my other junk may find its way on top of it!
I need to make sure that I can get at the USB cable - as you use it for playing stuff of memory sticks as well as connecting to the iPod cable.
iPhone... I'm happying with my Nokia N95 at the moment - be we'll wait and see!
Offline Pabs32
  • Hello
« Reply #23 on: 21 June 2007, 23:11 »
I have a hole already in the glovebox above and to the right of where you are supposed to put your manual. Big hole can't miss it. I fed IPOD cable through that. u even get a little VW logo on you ipod.
CW Ed30 3dr DSG, Xen, Highline, Satnav, IPod, Park sensor, Sunroof
Offline p3eps
« Reply #24 on: 26 June 2007, 23:15 »
Finally... The Alpine iDA-X001 and KCE-300BT are fitted (for now!)
They arrived on Thursday night... I opened them and got a little scared by the amount of wires!
The car came back on Friday lunchtime from the dealer.  I got a call saying it had been fixed - but they'd damaged my inside door panel trying to get the door open.  The part has been ordered - but is on back order so may take a week or 2.  Its beside the lock - so you only see it if the door is open.
Anyway... with the remainder of my lunch break on Friday I finished wiring in my Micro Roadpilot.  I went for a run round the mountains on Saturday afternoon and put a few hundred miles on the clock.  When I returned, I sat in the car and took out the courtesy light, followed by the drivers sun shade... and then ran my handsfree Mic from there down into the cubby under the light switch.
On Sunday I took out the ashtray, gear lever cover and most of the center armrest and ran my iPod USB cable into the under the ashtray.
On Monday I was feeling brave - so I dissasembled the whole dash as described in the tutorials and removed the standard stereo and the aircon controls.
I then fitted the new stereo using the Blaupunkt CanBus adapter and the genuine VW fascia adapter.  I used some double sided tape and stuck my 300BT in behind the aircon controls, and then using plenty of tie wraps fitted all the wiring so that it didnt rattle.
Everything seemed to be working well until it started getting dark.  I put my lights on, but the stereo did not dim like its supposed to with the CanBus... and the stereo is extremely bright!!  After several phone calls to Alpine and Blaupunkt it turns out I dont really need the CanBus!  Funnily enough I ended up speaking to a guy from Blaupunkt living in Amsterdam whos originally from 20mins up the road from me!  He owns a MK2 Golf and was advising me on how to fit the stereo without the CanBus!  It will require a bit of fiddling with the wiring as per some tutorials kicking about - but the CanBus seems to tick and make funny noises - so I'd rather do away with it!
Looks like I need to connect my Orange wire on my Alpine (illumination) to the back of the light in the cig lighter.  That way it will get a 12V signal when the lights come on - and that should dim my stereo display.  I will need to tap into the back of the light switch to get the switched and permanent live - but this seems easy enough.  I'll live with the brightness for the moment as I'm away on holiday on Saturday... plus I need to order an aerial adapter before I do it.
I'm not really looking forward to starting again - but it will be less wires and adapters to tie up this time!  I'm still trying to figure out what I'm going to do with the iPod cable in my armrest!  I'd quite like to put a dock in - but I'll sort that out another day.
Heres a rather blurry pic of the install:
And heres a pic for SteveS to let him see the difference between my front non tinted and rear tinted windows:
Offline SteveS
  • GTI ED30
« Reply #25 on: 26 June 2007, 23:37 »
nice one!! looks mint mate!
hey, if your going to sell the canbus let me know and i may take it off your hands for a good priceo :)
cant wait till mine comes in!
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline p3eps
« Reply #26 on: 26 June 2007, 23:53 »
I'll get it changed over when I come back my hols and see whether I need the CanBus or not.
I'd better order the aerial thingy just now before I forget!!  It might come in time for me to try reinstalling before I go?!
Very please with the interface and functionality of the stereo.  The bluetooth is cool because it lets you stream songs directly from your phone, and control them using the stereo... but the handsfree doesnt seem to be properly compatible with my Nokia N95 as I cant transfer my phonebook  :angry:
Perhaps its something they'll update eventually
Offline SteveS
  • GTI ED30
« Reply #27 on: 27 June 2007, 18:51 »
keep me posted  :evil:
SteveS
Offline AlanH
« Reply #28 on: 27 June 2007, 18:53 »
Looks good! Mine gets installed on Friday - can't wait :nerd:
Offline p3eps
« Reply #29 on: 27 June 2007, 19:19 »
I think I need to hack my roadpilot apart and change the LED's in it to blue!  The green doesnt go too well!
Hopefully when I get the Alpine's dimmer working properly it wont be so bright and will match the temp controls a bit better!
