Author Topic: Manifold replacement - KR  (Read 759 times)
Offline kkh120
« on: 15 June 2007, 08:05 »
Looking to swap a 50mm for a 42mm on a KR. Haynes is its usual self.
Looking at getting the injectors out, they will have to come out first to allow removal of the lowere manifld section. How do you get a grip on them to pull them out when they are so far in?
Any tips would do the job....thanks.
Mk2 8v and 16v.
Always looking for bits!
Offline Haribo!
Re: Manifold replacement - KR
« Reply #1 on: 17 June 2007, 18:24 »
you dont have to take the injectors out  :smiley: just use a long thin bar with a ?6mm? hex bit on it cant remember what size even tho i did it just yesterday  :huh: :undecided:
Offline kkh120
« Reply #2 on: 18 June 2007, 13:44 »
How did you get the lowere manifold out passt the injectors?
Dont they sit in housings that go through the lower manifold?
Mk2 8v and 16v.
Offline pegasus
« Reply #3 on: 18 June 2007, 18:31 »
yes, the injector seats are in the lower inlet manifold. Just pull the injectors out, they will need a bit of persuasion though.
1.8 20VT GTI
Offline Haribo!
« Reply #4 on: 19 June 2007, 03:21 »
oh i see what you mean now, i thought you meant they were in the way of the bolts,
« Last Edit: 19 June 2007, 03:32 by HÄR!ߨ »
