Author Topic: mk3 annoying noise  (Read 4159 times)
Offline drc12369
Re: mk3 annoying noise
« Reply #10 on: 09 December 2012, 20:37 »
My mk3  agg makes an annoying rattle nouse when i accelerate too, did this work for you?
Offline supergeeman
  • 97/P GTI8v
« Reply #11 on: 09 December 2012, 21:45 »
hope somebody can help
Ive got an annoying noise when i accelerate sounds like its coming from underneath the drivers door if you blip the throttle it sounds like a sort of pinking noise. The car has been in the garage checked over timing is fine,they said its not pinking, the heatshield on the cat has been taken off, the heatshield that runs the lenght off the car is fine and it doent make the noise when stationary only when under load the car runs fine no issues at all can anybody help cheers andy
Hi, I had exactly this problem for ages, I fixed it yesterday.....at last,  :smiley: I thought it was the exhaust manifold blowing! Try this.....
If you look down the back of the engine on the drivers side you will see a long flexible rubber shroud that encloses the steering column. It runs from the bulkhead down to the steering rack. The bottom bendy bit of the shroud was perished with a big hole and its right by the down pipe. The noise from the downpipe gets piped through the hole directly up this rubber shroud and into the car. What I did (with some difficulty, cuts and bruises etc) was to seal the hole with duct tape. Its very tricky, crude and hard to get the tape to stick but I did it and I can't believe the difference. This morning driving to work I forgot I'd had the problem 'til I read your post so I took the car out again before replying just to check........virtually nothing to be heard. I guess the tape will keep falling off but at least I know the bl**dy problem now and I know its worth getting a new rubber thingy, damn tricky to fit I expect. Maybe some old inner tube and long cable ties would be a better fix.  Hope this helps, J
excellent post! have the same issue, thought my manifold/downpipe was blowing! had it checked, nothing found...will be getting the duct tape out! cheers  :smiley:
I'm not normally a praying man, but if you're up there, please save me, Superman!
Offline tweed
« Reply #12 on: 09 December 2012, 21:56 »
Five and a half years  :shocked:
Offline drc12369
« Reply #13 on: 10 December 2012, 07:31 »
Using that search feature may actually pay off  :laugh:
Offline tweed
« Reply #14 on: 10 December 2012, 11:11 »
Everything has been covered before you just got to find it
Offline VR6_Wherry
« Reply #15 on: 10 December 2012, 11:24 »
EVERYTHING! :grin:
