Yep, Thats the same seller I got mine off. Apologies, I paid £75 not £60.
It came brand new unopened.
There was already a hole at the top of the glovebox, so did not need to do any drilling.
The instructions that come with is are good. The hardest part of the job was getting the brown wire out of the existing radio connector. On the instructions it tells you to use a VAG tool which I didn't have.
I found 2 safety pins pushed down the side if the connector did the trick.
The kit comes with a little connector with the same brown wire connection on, so there is no wire cutting just plug and pray.
I think there has been a few posts on what info you get on the headunit.
My experience is that the MFD2 reports that it has a CD in magazine slot 1 and another in magazine slot 6.
Both virtual "CD's" have 99 tracks each. You do not get the actual track name it just says CD1 Track 1 etc. (this is also displayed on the highline computer)
