Author Topic: How do i mount 130mm mid & tweeter in the dash of a mk2 ??  (Read 5608 times)
Offline AZIM
Ive got loads of MB QUARTS speakers lying around , so i thought id use them in my new motor im building.
Ive got a set of 3 way components which consists of bass 160mm mid 130mm & 1" tweeter.
Ive also got 130mm coaxials which could be used as part of the 3 way components .
Any suggestions on how to mount the 130mm & tweeter or coaxials in the dash location eg maybe do a dash build using fibre glass & mdf.
Any advice on angling components would be appreciated.
The dash is out of the car at the moment so i could do the work before installing it.
Any pics of similar work would be appreciated
Offline tommk3cab
130 mm will nearly fit in the standard dash locations, just need a bit more depth, if you can do that I would get the 130mm componants in there, but thats only because i like things looking stock ( probably because ive been robbed before!)
I would fit the 160mm in the doors angled slightly upwards if possible depending on if they will fit in the stock mountings ( if you have them on your mk2 ) or if you are going to make a build.
and leave the 130mm coaxes but if you really wanted to put them somewhere, i would put them in a small build where the front and back doors seperate, near where the front seatbelts dissapear into the pillar but nearer to the roof, unless of course you just fancied sticking them in the back somewhere?!
and the tweeters either ( if you want to do a proper job) in the windscreen/door pillars, there is a sticky thread on here about how to make it look good. or (for quick and easy!) on the roof lining near where the grabhandles would be in the back, but in the front, if there was any!
as for the angle of them all, just as 'towards' the listener as possible really, so, basically if you could use them as headphones that would be best!
Offline AZIM
tommk3cab thanks for the reply.I agree withnearly all of what youve said .
There are two points im concerned about .
1. When i previously fitted 130mm components in the dash location , i found the air vent plastic tube which runs directly underneath stops me fitting the speakers flush as id like .
Is there any way of deforming the vent tube without damaging it (Heat it & reshape it).
Also would the rear of the mirrors not be a good position to angle the tweeters or is half way up the a post the best position .
P.S ive got 2 amps for the system
Denon dca800 & Kicker ZR240 for the 15"Celestion ADH (and Phoenix Gold 215x eq)
                                Cheers AZIM
Offline tommk3cab
thats what i ment when i said the 130mms in the dash will need a bit more depth to fit. with the dash out i thought you may be able to see a way to give them a bit more depth, we never could?!
 we didnt even see it was part of the vent system just realised they didnt fit and replace with 10 cms, 13s would be better though, if they would/could fit. where does that particular piece of the vent system go to and where does it come from? ( if you can see?!) unless it can be moved easy that idea may be screwed then!
http://www.talkaudio.co.uk/vbb/showthread.php?t=159311
thats the thread about the tweeters in the post I said about, at the end they look mint, its in a mk3 but it will be the same idea. The only thing that may cause you problems is you will need tweeters with cups for this kind of build really and i dont know if you have cups with yours?, it is possible to do it without cups though.
as long as there is kind of a direct path to your ear from the tweeter it should be sound ( so pretty much if you can see them its ok!) mid post will be slightly better as its more inline with your ear, but lower down will be nearly as good i would have thought. the closer the better really as long as its a balanced sound with the rest of your system.
depends a lot on what music you like, with a 15 inch sub i assume hip hop or d+b?.
Offline AZIM
tommk3cab:where does that particular piece of the vent system go to and where does it come from? .
It comes from the center of the dash & branches out to the side air vents .
It can be removed & modded .
I assume you can platic weld it into the shape you require, to give clearance to the mids without noticible effects to the flow of air to the vents.
Maybe i should get a spare one & use a hot air gun to try & deform it to the shape required.
The Clestion ADH15 in a sealed box is a great sub for sq in my opinion, lends it self well to all music
« Last Edit: 09 June 2007, 16:23 by AZIM »
Offline tommk3cab
i would try changing one if it wasnt too much hatle to get a second hand one or and old one.
the reason i mentioned the music you listen too is because if you listen to music with a lot of voices then you may not want the tweeters too close to you as it may sound slightly unbalanced, for drum and bass and dance type music though, pretty much the closer the tweeter the better, as long as you have the bass to cope with the, in effect amplified high notes ( although not amplified just closer to you)
you can usually balance the sound pretty well on HU's themselves nowadays anyway, to a degree anyway.
Offline AZIM
That lot was a bit deeper than i was expecting. :huh:
I think i will mount the tweeters near the mids , in the back of the door mirrors.
This would be good for all kinds of music, i should be able to angle them a little as i have a few different speaker mounts for the tweeters.
Offline Heyho
I have the tweeters in my mk2 on the mirror backings, it really is the easiest location, and gives good results.  I think you'd be hard pushed to fabricate a pillar builds on a mk2, as the trims are very narrow - they'd need to be pretty small drivers.
I've actually got the mirror backing trims screwed to the door - I cut off the mounting lugs and drilled through then countersunk - I was pretty sure that the weight of the tweeter would eventually pull the trims off.
When my install is finished, I'll post up some pics, but I can't promise when that'll be!
Offline AZIM
Heyho ,Id love to see some pics of youre system .
Offline tommk3cab
fairplay then stick them there, you wont notice much difference just the ones in the thread I linked to looked proper mint and I cant wait to do mine in a similar way! its been a long time since i had anything to do with mk 2's, I remembered running some wires for some roof lining mounted tweeters through the pillars, but i cant remember what the pillars looked like, thought they were pretty similar to mk3's, obviously not!
