Author Topic: B Pillar wind rush noise?  (Read 3393 times)
Phil mcavity
Re: B Pillar wind rush noise?
« Reply #10 on: 05 June 2007, 13:56 »
 :laugh:
Offline telboy
« Reply #11 on: 05 June 2007, 20:22 »
Stealers had the car in today and fitted new inner door seals on all four doors, will test tomorrow to see if this has improved things. :huh:
 :undecided:The only thing is that when I looked at the rear door inner seals they don't actually meet, there's a gap of about 1-2mm so I phoned up the stealers only to be told that was the norm?
Does anyone else have a small gap on the bottom of their rear door inner rubber seals? Sounds petty I know but when you've been trying hard for ages to get this problem sorted, you'll double check everything! :angry:
Offline Teutonic_Tamer
« Reply #12 on: 06 June 2007, 09:41 »
telboy, a piccy might help.  :wink:  :smiley:
I feel like a homo
Offline telboy
« Reply #13 on: 06 June 2007, 20:42 »
Went to a different vw stealer today, most impressed, they spent loads of time on the car, loved my VW licence plate and have booked the car back in for some further replacments under warranty. They did take me out in a nearly new GTI to compare noises and mine was no worse, so I do feel a little better. Re the gap on the inner seals, this is normal and I looked at a few other golfs while at the dealers and they are all the same so no worries. :cool:
The dealer are going to try and improve the seal compression on the front doors to restrict the noise further, so fingers crossed. :smiley:
All in all I'm a tad happier now and will start enjoying the car! Thanks to all for your replys!!!
