yellow with white is NOT ignition live, its speed sensitive volume adjustment, done nothing on 99% of headunits
I believe this was part of the expensive aktiv speaker system, either that or VW supplied headunits make use of it.
As for ign live only the very late MK2s got it, they had a red/brown 'key in ignition' feed
Any 90spec MK2 can have this retro fitted, you have to add the missing pin into the ignition switch plug (Pin 'S' or 'SU') and run it to the headunit.
On a pre-90 MK2 ign live is easy to set up, drop the fusebox and you'll see 2 groups of spare spade connectors, one side live, the other ignition live. Run a wire from there, but check the spades with a multimeter as some are not hooked up
