Author Topic: Cutting out under load  (Read 2270 times)
Offline Mew
Re: Cutting out under load
« Reply #10 on: 28 May 2007, 13:58 »
If you disconnect the coil to dizzy lead at the dizzy end and place it in the lift eye of the engine, does it just spark once when you turn the engine over or does it spark repeatedly?
Offline Darkc0re
« Reply #11 on: 28 May 2007, 14:18 »
it just sparks once
Offline Darkc0re
« Reply #12 on: 28 May 2007, 14:21 »
do you think the coil is at fault? i found a spade connection on the back of the distributer that has no wire going to it? should this be connected to something?
Offline Mew
« Reply #13 on: 28 May 2007, 14:22 »
If it just sparks once then that sounds like the hall sender. Exactly what happened to me when my hall sender went!
Offline Mew
« Reply #14 on: 28 May 2007, 14:27 »
Well, i say when it went.......... looking back now it may have just been the connection. Give it a jiggle on the dizzy to see if that starts it, or even pull the rubber boot up that goes around the 3 wires then have a go.
Offline Darkc0re
« Reply #15 on: 28 May 2007, 14:28 »
have a working hall sender on a spare dizzy on a spare engine, going to try that now.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #16 on: 28 May 2007, 14:30 »
Happened on ym amtes corsa, exact same symptoms, to the finest detail..
New dizzy was the key in the end, was an easy swap from a scrap  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Darkc0re
« Reply #17 on: 28 May 2007, 16:56 »
just changed the hall sender over from another dizzy and still having the same problems :( could it be the coil?
Offline Darkc0re
« Reply #18 on: 28 May 2007, 20:32 »
sorted now, schoolboy error, put the dizzy back in 180 degrees out  :embarassed: So it was definately the hall sender as it seems fixed now, just took it for a long drive and its run fine, the old hall sender looked very scored and manky
« Reply #19 on: 28 May 2007, 20:59 »
apart from the 180deg, as i say same story we had  :smiley:
Quote
