Author Topic: Air Bag Light!  (Read 1961 times)
Offline Simonet
  • Pearl Black GTI ED30
Air Bag Light!
« on: 25 May 2007, 19:36 »
Hi All, just fitted the nokia Hands Free Car Kit and followed the instructions which are really great!!
Only Problem is..... The Air Bag Light has come on!?!?!?
I've run the wire down the edge of the A Piller as shown, and only used my finger down the rubber of the door seal.
Any ideas???
Thanks
Simon
Offline Manu_R32
Re: Air Bag Light!
« Reply #1 on: 25 May 2007, 20:09 »
I have the same problem!! Every time i start my car it goes DING!! and then it says airbag fault...the light doesnt get off  :sad:
OSIR Front Splitter - OSIR Rear Diffuser - RNS 510 - JL Audio Cleansweep - JL Audio 400/4 Amplifier - JL Audio ZR650 - Recaro Bucket Seats - 3.2 V6 of Pure Power!
Offline Trefor
Re: Air Bag Light!
« Reply #2 on: 25 May 2007, 21:33 »
Where are you powering the kit from? The VW loom can be a bit sensitive.
I found this out the hard way, it didn't work in the way Docs instructions showed. I triggered a few fuses which the dealer had to sort out (luckily dealer didn't twig it was the kit fitting that caused the probs and did investigation under warranty - the fuses were hidden ones, not in either fuse box).
Offline AlanH
Re: Air Bag Light!
« Reply #3 on: 25 May 2007, 22:22 »
I believe this problem has also appeared when owners have had aftermarket headunits fitted, and the battery has been disconnected. Usually sorted by a trip to the dealer and the removal of VAGCOM error codes.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline Simonet
Re: Air Bag Light!
« Reply #4 on: 25 May 2007, 22:41 »
I fitted as the Doc instructed, power from pin 20 on the air con. I guess it's a trip to the dealers!
I think my auto lights may be affected too!!! They seem to come on when light!
My phone works though!  :laugh:
Offline Cass
Re: Air Bag Light!
« Reply #5 on: 26 May 2007, 00:04 »
You probably removed the electrical connector to the centre dash vent, thereby triggering an airbag fault code. You need to go to a VW dealer to get it recoded.
See point 6b in this installation thread:
http://forums.vwvortex.com/zerothread?id=2945481
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline Simonet
Re: Air Bag Light!
« Reply #6 on: 26 May 2007, 17:35 »
yup, I removed it!!!
Well hopefully the dealer will reset, I'll just keep my gob shut!
Offline p3eps
Re: Air Bag Light!
« Reply #7 on: 26 May 2007, 20:51 »
Hmmm... is it possible to change the stereo without removing this one?!
I have a CanBus adapter, so I won't need to modify any wiring.
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline Simonet
Re: Air Bag Light!
« Reply #8 on: 27 May 2007, 10:40 »
yeah, you can place the vent (still conected) on the dash, I thought it was easier to remove it!! Doh!!
