Author Topic: Running Probs  (Read 4689 times)
chris
Running Probs
« on: 05 July 2002, 01:24 »
I'm having a bit of probs with my new mk3 it seems to using sh!t loads of fuel ie 250 to a tank and it seems to running like a pig.
Ive took it to my local vdub dealer and they said no fault found which is bollocks can anyone help??
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline olstar
  • I love YaBB 1G - SP1!
Re: Running Probs
« Reply #1 on: 31 December 2002, 23:08 »
dont no if mine is quite that bad but it does drink quite a bit of fuel...
i will re-set my trip meter next time i fill up..
and i will let u no..
Do you drive ur car sencibily?
that may be why..
Offline Pimpster
Re: Running Probs
« Reply #2 on: 18 January 2003, 00:31 »
I had exactly the same problem on my Mk3 97 8v. I was getting 210 miles to a tank, it was down on power and sounded dog rough. took it to local vw dealer. problem was a faulty Temprature Sensor. When this was replaced the throttle has to be recoded. Also get the Throttle Valve control cleaned out. I did all this and it runs absolutely superbly. 28-30mpg average round town. loads more power and really smooth. VW garage charged me ?70 for the temperature and sensor.
Offline M1ST
Re: Running Probs
« Reply #3 on: 08 February 2003, 22:06 »
Hi All,
I wonder if anyone of you have experienced this before. But my Golf Mk3 8v GTI, when I start it from cold it just wants to cut out. However if I press and hold the accelerator and keep it at idle manaully it wont switch off, but there is serious lack in power when driving it and very slugish. When I put my foot down, it doesnt accelerate that well at all. My local garage reset the ECU (cleared the faults off in memory) cos they advised that there was nothing wrong with any hardware parts and a fault with the Temp Sensor was showing but when they checked the sensor - it was fine, after the ECU reset, the car then was fine for about 2 months. But it has now started doing it again. Any advise Please?
M1ST
