Author Topic: Len's Mk3 16v ~ The Rebel Car! New Wheel Pics Page 90  (Read 610674 times)
Offline Len
Re: Len's Mk3 16v ~ The Rebel Car! New Wheel Pics Page 90
« Reply #1270 on: 04 June 2015, 13:02 »
I've gone back over this thread to find out what engine you are using, seems similar to mine.  The last picture works for me.
Are you able to tell me if the holes for the timing discs in the ABF and diesel cranks are in the same place when compared to each other?  I'd like to confirm if the ABF timing disc sits in the same place as it should when changed to the diesel version.
I have a timing disc to put on to a diesel crank in an ABF block, I just have to strip it down first.
Hopefully this will solve your problem.  Are you using the new management?
I am using a 16v abf block bored out plus a TDI diesel crank. this gives 2092cc
If you are asking about the crank sensor trigger wheel, look at the photo.
That is the two of them in a vice. the front one is the diesel which is smooth with a gap. the one behind is the 16v one toothed with a gap!
Also the diesel crank has a lug that sits in the hole you see. So that's why they are in the vice so I could drill a corresseponding hole in the 16v one.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #1271 on: 04 June 2015, 13:06 »
Not using different management for now. I wanted to run the engine in before I get the throttle bodies and new management!
This has been my real problem because the trigger wheels are different and the crank sensors are different to!
I will need a HAL type for the new set up!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #1272 on: 04 June 2015, 20:05 »
Couple more progress pics!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #1273 on: 04 June 2015, 20:06 »
Gearbox back on!
www.sas.org.uk
www.the-ace.org.uk
VW BUSH
« Reply #1274 on: 04 June 2015, 20:26 »
Did you go for a different fd on the box?
I'm too lazy to go back through the thread :laugh:
Fyi I can get trigger wheels made if you know what you want
Offline Len
« Reply #1275 on: 29 June 2015, 12:36 »
No still a standard gearbox for now.
See how it goes after the final satge.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #1276 on: 29 June 2015, 12:39 »
Have broken the Dizzy!!
The inner where the two prongs go into the end of the cam, there is a dark metal ring and somehow I have split that in half!!!
F**k knows how!
So dunno whether to chance it, as its held together by a coiled spring or get a new dizzy!
www.sas.org.uk
www.the-ace.org.uk
Offline gazareth
« Reply #1277 on: 29 June 2015, 23:49 »
personally I wouldn't chance it. it might be ok but it might damage something instead. and you know it would always be in the back of your mind if it wasn't right :wink:
Offline Simeon
« Reply #1278 on: 30 June 2015, 03:28 »
Good progress :) New dizzy for sure
Offline Len
« Reply #1279 on: 30 June 2015, 10:41 »
Yes guys you are right!
So if anybody has a spare Dizzy ......
Oh and the earth strap from coil to head too!  :wink:
www.sas.org.uk
www.the-ace.org.uk
