Author Topic: New to the forum...saying hi!  (Read 4298 times)
Offline vw-bob
Re: New to the forum...saying hi!
« Reply #10 on: 18 May 2007, 21:14 »
hey  :smiley:
Offline gteyes
« Reply #11 on: 18 May 2007, 21:25 »
try disconnecting the mass meter and see if it revs out ok also bring it for a spin and see if it drives better with it disconnected if it does air mass is gone, also at the inlet manifold under a black bracket there a boost controll vave there (grey in colour) have came across it before where it sticks  causing the same probs as your car
best of luck with it
Offline vaughn
  • now team wagon, and team grumpy trainee
« Reply #12 on: 18 May 2007, 22:34 »
arrow
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
Offline Neaty
« Reply #13 on: 19 May 2007, 16:02 »
arrow
are you slick in disguise?  :grin:
Offline GemsGti
« Reply #14 on: 19 May 2007, 17:53 »
Hey all,
Yeah car is still losing power at 4000 rpm, is not drivable at all.
Offline vaughn
« Reply #15 on: 19 May 2007, 17:58 »
arrow
just filling in while he`s away  :smug:
Offline Neaty
« Reply #16 on: 19 May 2007, 18:09 »
delegation amongst the moderators, like it  :smiley:
Offline Len
« Reply #17 on: 21 May 2007, 09:34 »
Welcome Gem.
I see topher is quick on this one! :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline topher
  • Administrator
  • fully functioning
« Reply #18 on: 21 May 2007, 09:46 »
ok.. next idea, and one that is often overlooked. take a look at the very thin vacuum hose that goes into the top of your diverter valve, it should be braided. check very carefully along it's length (make sure to follow it right to the end) for hard/brittle areas. it can be easy to miss since its a braided, but as it gets older, the heat from driving makes it very brittle and it cracks and leaks.
Offline tom26
  • team chumpy.
« Reply #19 on: 22 May 2007, 09:06 »
hi there.
