Author Topic: MK3 GTi 16v Gear Selection Problems  (Read 10532 times)
Offline garfayliu
Re: MK3 GTi 16v Gear Selection Problems
« Reply #20 on: 11 June 2007, 15:08 »
I tried that this morning, it was a fair bit off centre so i slackened, moved, then retightened..
If anything it seems worse!
Better set it back to what it was!
Offline Overseer
« Reply #21 on: 19 June 2007, 12:41 »
picked a mate up from the local dub specialist this morning.. had a quick word with the guy there... he seemd to agree that as theres no crunching it could be a worn something.. or alignment.. will be booking it in for investigation (and hopefully fix).. soon..
Offline mk3jonny
« Reply #22 on: 19 June 2007, 17:25 »
Just in case this snippet may be of use, i had the first reverse fifth thing on my mk2, had the plastic ball socket bit beneath the gear lever replaced and it cured it, it is quite common for these to wear and when they do obv gear selection gets a bit tricky. It is a cheap fix though! If there is no crunching then that is almost certainly the prob. Hope that helps add weight to that theory for you.
Offline Overseer
« Reply #23 on: 28 June 2007, 09:35 »
i'm booked in for thurs 5th...
theres no rhyme or reason to it.. if i think i've discovered a "trick".. it'll stop working..
i thought for a while that putting it in neutral, letting of the clutch.. putting the clutch in again and then shifting was working.. it did the first two times..
came 20 miles down the motorway from my new girlies this morning.. couldnt get in 5th for the life of me for the first 10 mins..
will check back into this post once its been looked at..
Offline colourcongti
« Reply #24 on: 30 June 2007, 20:12 »
has anything been found out about this as i have the problem with 5th gear been a pain to get into and now 1st and 3rd are getting bad
Offline Pete Taylor
« Reply #25 on: 01 July 2007, 07:09 »
I've got come gear linkage bits to order monday to fit hopefully wednesday which should fix that same problem i'm having in my cable change box which I believe has worked for someone before, if it fixes the problems i'll be putting together some cable change box lever repair kits for the 16v and VR6
« Reply #26 on: 01 July 2007, 19:48 »
let use know how you get on mate
Offline Gurm X
« Reply #27 on: 03 July 2007, 09:12 »
I have the same problem, there is no crunching tho, but to select 1st gear is a mission, i also use the 2nd gear to 1st gear method.
Please let us kow how you get on as I would really like to sort mine out too
Offline Overseer
« Reply #28 on: 03 July 2007, 22:19 »
2 days :)
Offline Pete Taylor
« Reply #29 on: 04 July 2007, 09:45 »
Well it seems i'm not going to have time to fit yet as the total closure on my car decided to break. It's constantly forcing my windows down so out popped the RAC man. My window motors and regulators are now disconnected and ten ton of sellotape is holding the windows to the doors. Cheers RAC man....
