Author Topic: 16v springs  (Read 1636 times)
Offline ecomoto
Re: 16v springs
« Reply #10 on: 10 May 2007, 19:39 »
cheers,so is it essential to get these spring caps for the front(60mm springs) as i am using standard shocks,if so where to i get tghem from?.thanks
Offline boneybradley
  • Back in a Mk3...
Re: 16v springs
« Reply #11 on: 10 May 2007, 19:54 »
the spring cap's are if you want to lower your car further otherwise use your original's....just ensure they sell you the correct diameter spring's as these change on 1994 from an 80mm pigtail to a 65mm pigtail and as other forum member's have proved even good?? places can get these mixed up (check this thread for info http://www.golfgtiforum.co.uk/index.php?topic=58602.0)                and one last thing I would buy a pair of top mount's as these wear alarmingly on the front (cost about £20 a pair but will save a good hour's labour later on)
