Author Topic: annoying red light what is it and how do i stop it?  (Read 3602 times)
Offline Dizzie
  • Make friends with your fast
Re:annoying red light what is it and how do i stop it?
« Reply #10 on: 06 February 2004, 14:42 »
mine's stopped doing that... for now.  ???
turbo
« Reply #11 on: 08 February 2004, 02:22 »
if your cars using alot of oil please try valvoline maxlife this stuff conditions seals and slows down engine aging this stuff conferms to
api sl / cf
acea A3 / B2
and is also apporved by tuv....
Valvoline's MaxLife motor oil is a blend of premium base oils with a seal conditioning agent, extra cleaning agents, additional anti-wear additives and friction modifiers. MaxLife is formulated to help condition engine seals, prevent leaks, minimize oil consumption, reduce friction, provide easier cold starts, maximize power output, resist thermal breakdown and reduce deposit formation.
check out this valvoline video......
http://www.valvoline.com/video/video.asp?VideoFileName=MaxLife
i'm using maxlife and my clocks on 197477! still going strong. mine does use oil about 250ml every 90 mile but i do thrash it everywhere so it will burn oil...
Offline Ant
« Reply #12 on: 08 February 2004, 10:09 »
After doing various bits and bobs on the car yesterday I had this light flashing constantly, went back under bonnet and checked fiddled with the wires on the rad and the one on the top of the tank, and problem went away (although I'm gonna find out which wires loose one day)
Offline Helios_Blue_Valver
« Reply #13 on: 08 February 2004, 17:37 »
must be a vw thing. mine does it as well. Thinking of replacing my water and washer resies with polished alli ones anyway so I'll replace the switch then. As long as the car has water and the temp gauge is reading good don't worry much about it. :)
Offline Golfgal
« Reply #14 on: 10 February 2004, 12:06 »
Bloomin annoying thou! My rev gage gives it some aswell.
Thou the mk1 temp lite does my nut in so jus think - it cud be worse! :D
V5 Beetle owner. I'm just here for the misfire threads....
Offline Onge
« Reply #15 on: 10 February 2004, 13:51 »
I had the flashing light problem on my Mk2,
Make sure your're not loosing water
then put a post-it note over the flashing area.
You will never have to look at it again
(helps if you like the colour yellow) ;D
