Author Topic: uprated headlight loom  (Read 2556 times)
Offline T_J_G
« on: 03 May 2007, 11:23 »
so i've got one and i haven' got a clue how to get it in... :huh: :grin:
Any phot guides round here or on another site?
Tim
Offline G174AFC
Re: uprated headlight loom
« Reply #1 on: 03 May 2007, 14:11 »
Don't know if this is relevant to your particular loom but it may be worth a read...
http://www.matey-matey.com/uprated_headlight_wiring.shtml
Hope it helps!
 :smiley:
If you like old school, here is another great forum - http://www.teamcs-racing.org/
Offline T_J_G
« Reply #2 on: 03 May 2007, 14:13 »
Hope it helps!
 :smiley:
reads that! thanks anyway.
Think i've sorted it with the resident forum master. Just got to get some terminals and i'll be away. :smiley:
Offline NixGTI
« Reply #3 on: 16 December 2007, 12:04 »
did you get your loom sorted? I'm looking in to doing mine. How easy was it?
Dont suppose you took any pics of it? or wrote down what colour wires go were etc?
Offline T_J_G
« Reply #4 on: 16 December 2007, 13:18 »
Nope I didn't end up doing it, was going to sell the car so i sold the loom, then kept the car and wish I had the loom :grin:
Offline Ben Lessani
« Reply #5 on: 16 December 2007, 22:23 »
i made up my loom, its a 20min job to do,
http://www.golfgtiforum.co.uk/index.php?topic=49436.msg410777#msg410777
read-y read read
Offline Dolly
« Reply #6 on: 16 December 2007, 22:54 »
how did u wire main beam into yours then, this diagram ive found only shows dipped.. is it a case of just using another relay and wiring it the same as the dipped? when i swop engines ill have a spare loom to play with, im think im going to relocate the battery to the boot at the same time and like everyone else, tidy up the wiring abit.
Offline Ben Lessani
« Reply #7 on: 17 December 2007, 00:05 »
Don't put the battery in the boot - its a bit senseless, there's plenty of room in the engine bay! I wired my main beam up by the same method I did the dipped, just used 2 relays per side each for the main + dipped beam, but I could have got away with simply using 2 relays total, but the risk with that is if 1 relay fails, you lose entire lights on both sides, mine is just setup with a little more redundancy.
Don't use the standard loom - it defies the whole point of it being uprated! Just get some 12v 20A 16 AWG (240W Handling) wire and a 40A relay, that will do the trick perfect, even when running 100W bulbs. Tidying the wiring is something I'm going to be doing with my car, I'm just going to use fabric tape like they use on new cars
REF. http://www.rbeelectronics.com/wtable.htm
Offline Dolly
« Reply #8 on: 17 December 2007, 10:02 »
i probably go for just 2 relays, if it goes and i loose all lights then so be it  :tongue: .. i guess its another spare relay for me to carry. cheers for the advice dude.
Offline rockhopper
« Reply #9 on: 17 December 2007, 17:51 »
blessani were will you get fabric tape from?thanks
