Author Topic: knackered head gasket  (Read 2092 times)
Offline l1ncs
Re: knackered head gasket
« Reply #10 on: 03 May 2007, 18:04 »
Its my own fault really, all the signs of a gone head gasket where there I just ignored them. Ive been quoted 250-300+ VAT (including head skim and cambelt change) at a vw specialist so might as well get it done there.
Offline monzablue16v
« Reply #11 on: 03 May 2007, 19:31 »
It will cost you about £100 plus time it's not a bad job I could probably get it done in half a day after doing it twice in the last month :( or take it garagewards, you can't give up on it and just sell it :)
Offline Bluefox
  • ...back again!
« Reply #12 on: 12 November 2007, 21:05 »
i bought the car off bluefox ran it for 4 months without any problems? only sold it cos i'd bought a TDI. sorry guy's if that makes me a bad person  :sad: i wouldn't of sold it with a head gasket problem.
Hm. Raking over old coals here perhaps, but I've just noticed it in the for sale section.
For the record, I sold it to Leedub for about £300 with no MOT or tax. Looks like he ran it for a few months before selling it on with a fresh MOT...
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
Offline Village Idiots
« Reply #13 on: 13 November 2007, 09:30 »
Are you sure it's definately the head gasket?
Oil coolers can fail and show similar characteristics. Oil in the water in the rad., sort of scummy deposit on the water in the header tank, but no water contamination of the oil (evidence of emulsified oil in oil filler cap) generally means oil cooler failed. Because the oil operates at a higher pressure than the water, oil leaks into the water but not the other way.
Does it overheat badly, this shows gasket problem.
Oil coolers are relatively cheap (less than £50). If it is the gasket and you do it yourself (not dead easy unless you've done quite a bit of spanner work) make sure you buy new head bolts and be scrupilously careful you torque them down exactly as it says in the manual or it'll probably go again. Good luck.
