Author Topic: Lay flat re wiper?  (Read 2209 times)
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
Lay flat re wiper?
« on: 05 February 2004, 21:06 »
How do you change to lay flat??
Is it a kit or as simple as revrsing some wires???
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
Blue MK2
Re:Lay flat re wiper?
« Reply #1 on: 05 February 2004, 21:41 »
cut your ignition off once the rear wiper sits flat. This is so the wiper stays in the flat position.
Now unbolt the wiper and place it in the normal upright position.
the wiper should now fall back to the layflat position when you turn the ignition on.
i did it the other way. Im not sure if it will work that way but let us know if it does. :)
Offline gti fly bye
« Reply #2 on: 05 February 2004, 23:04 »
nope, now it go's the other way, right to left???????
Whats the other way???
Offline modulater
« Reply #3 on: 05 February 2004, 23:27 »
Remove the boot panel and undo the nut that holds the wiper linkage on to the end of the motor spindle, turn the arm through 180 degrees and reattch it to the spindle and do up the nut.
You may have to adjust the wiper arm to make sure it sits how you want it.
Offline gti fly bye
« Reply #4 on: 05 February 2004, 23:34 »
Nice one, that makes sense, cheers.... 8)
Veedubgt18v
« Reply #5 on: 11 February 2004, 19:45 »
check www.matey-matey.com they have a tech article
Offline ASH
  • its a way of life!
« Reply #6 on: 11 February 2004, 20:13 »
Offline modulater
« Reply #7 on: 11 February 2004, 20:53 »
cool ;)
Offline gti fly bye
« Reply #8 on: 12 February 2004, 00:08 »
Cool, cheers, is it the mk3 rear wiper that is rounded platic, new lookin???
