Author Topic: Respray  (Read 1841 times)
Offline DannyL
Re: Respray
« Reply #10 on: 30 April 2007, 17:35 »
I will be preping it myself with the help of a friend, i will ring around tommorow for some prices.Also whilst im on here i want some new trim to complete the look do you know where i can get a big bumper pack, and how easy are they to fit is it just a clip off clip on job?
Offline GTi_Lee
Re: Respray
« Reply #11 on: 30 April 2007, 17:45 »
Apologies dont mean to hijack the thread but say you had a golf with "surface rust" and you had that panel resprayed. Would it look out of place compared to the rest of the car? Since it is new paint on one section and the rest of it will be like 16yr old paint.
It's just I'm looking for a golf but being a pretty old car I'm expecting one with some rust and obviously I'd like to sort it but dont want a patchy looking car. A full respray sounds like too much cash but I could possibly manage small areas that needs to be done.
Thanks
Richie Lee
Offline bomp
Re: Respray
« Reply #12 on: 30 April 2007, 19:00 »
Well, a friend of mine who is a panel beater/sprayer says the going rate to prep a panel, door/wing/bonnet etc, is £70 a panel.
And £800 minimum total respray. I assumed that was a friend price.
@ GTI_Lee, A good body shop will colour code your car anyway. Ask them to buff the rest of your body work so the new panel does'nt stand out (It'll cost of course).
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline Thom89
  • Looking for an "Icebreaker"
Re: Respray
« Reply #13 on: 01 May 2007, 00:33 »
Ive just spent apprx 200 hrs prepping and painting my 3dr 16v.. a small amount of welding was required to the rear wheel arches (rot on wheelarch fixings) small rot repair on tailgate, 2 new genuine front wings... paint, materials, panels, decals, fixings, new windscreen. alone comes in at just under £1000!!   plus the labour, 200hrs@£25pr/hr = £5000, plus vat  Obviously Ive not had to pay for the labour, but that is a figure that any well run bodyshop should be charging for that type of work.. the stories that you hear of cars going in for a respray, and not seeing the light of day for a year or more is more than likely due to the money situation..ie not enough of it!
Most of the time that went on my car, was setting the door and wing gaps to perfection, closely followed by block sanding and polishing, this is where time runs away!
If you have a good car, mimimal rust, and origional paint..then £1500 is a good starting point! any less than that. corners are being cut!!
I would forget self prepping, you often make more work for the bodyshop, putting your c*ck ups right! just remove the lights and bumpers, trims.. leave the glass in place, this can be popped in minutes by the shop..
Tom
« Last Edit: 01 May 2007, 12:53 by ...joe »
Offline KittyMk1
  • ~ VolksGirls.co.uk ~
Re: Respray
« Reply #14 on: 01 May 2007, 08:18 »
yeh i wouldnt prep it yourself unless you know what ur doin and can get it perfect. when i used to work in a bodyshop we used to get loads of jobs in which havent been prepped right.
Offline Philpy
Re: Respray
« Reply #15 on: 01 May 2007, 23:45 »
It all depends where you go, what you want is a sprayer who does it in his own time but has all the gear, my mate had his car sprayed pearlescent and it came to around £1000 Paint was over £350..... so the work was around £650.....
