Author Topic: Stalling at junctions  (Read 1849 times)
Offline takethefifth
Re: Stalling at junctions
« Reply #10 on: 01 May 2007, 03:56 »
Do the standard sort of checks for the hunting idle problem, blue temp sender, throttle switches, vacuum leaks etc.
Clutch being dodgy shouldn't affect it. :smiley:
Offline tom26
  • team chumpy.
« Reply #11 on: 01 May 2007, 11:28 »
i had this very problem with my 16v. would cut when i dipped the clutch - especially at junctions. i changed my isv which didn't help. also replaced all the vacuum hoses as i suspected an air leak too. mine turned out to be the micro switch on the throttle mech was not being pressed when the throttle was returning to idle. i don't know if 8v's have a simular switch? alligning this switch fixed the problem for me.
Offline T_J_G
« Reply #12 on: 01 May 2007, 13:11 »
another thing if it's out of gear it'll return the idle spot on.
Offline tom26
  • team chumpy.
« Reply #13 on: 01 May 2007, 15:42 »
that is strange! if it returns to idle perfectly when not in gear but cuts when a gear is engaged with the clutch dipped?? any ideas anyone??
Offline T_J_G
« Reply #14 on: 01 May 2007, 16:39 »
maybe worth getting the clutch done then..there goes another £171 that i really can't afford! got £100 put away for next payday but maybe i should get it done before?
Tim
oh and a big thank you to everyone that's helping me out at the moment  :smiley: greatly appreciated!
