Author Topic: in the middle of my 2.0l conversion and WTF!!  (Read 1811 times)
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« on: 24 April 2007, 23:46 »
well i started the engine swap today but finding out that it aint so straight forward as all the info leads you to believe.
the 2E block was bare when i bought it so was planning to swap all my PB engine stuff over, so far i have found that the mk1 gti oil cooler i had fitted wont fit the 2E, the power steering pump bracket is fouling the altinator so i only have about 20mm of adjustment to tension the belt.
can anyone tell me if they have had these problems and how to overcome them as my car is in bits and i dont want it to drag on.
thanks guys
Offline Mew
Re: in the middle of my 2.0l conversion and WTF!!
« Reply #1 on: 25 April 2007, 00:33 »
Have you got the 2e alternator bracket? Bolts on where the power steering bracket goes.
Offline jase555
« Reply #2 on: 25 April 2007, 00:48 »
no, but i would need the mk3 altenator too wouldnt i? the block was bare so all i have is mk2 bits to put on. none of the 2.0l coversion threads say anything about this. they all say you just swap everything.
Offline Mew
« Reply #3 on: 25 April 2007, 00:52 »
From what i was looking at on mine, to fit the mk2 alternator you still need the bracket that bolts on to the block, where the power steering bracket bolts on.
Now i may have this completely wrong, as i was just cross referencing it with other pics i had seen. Also, i don't have power steering so not 100% on the bracket set-up there!
Do you have any pics of yours in it's current state? Might help a bit!
Offline jase555
« Reply #4 on: 25 April 2007, 01:03 »
not atm will post some in the morning, waiting for my new phone. should be here tomoz.
standby.
« Reply #5 on: 25 April 2007, 11:34 »
what about the waterpump, are you using a 2e one or a MK2 one?
Offline jase555
« Reply #6 on: 25 April 2007, 22:57 »
my mk2 one............  :undecided:
« Reply #7 on: 26 April 2007, 00:04 »
I don't get it, the alternator is miles away from the pas pump!
Offline j_s
« Reply #8 on: 26 April 2007, 10:47 »
I think only pics will help for people to comment, your new phone arrived yet jase?
James
Offline bomp
« Reply #9 on: 26 April 2007, 12:38 »
This page may be of use, just for some reference for other parts to use.
http://www.rabbitgtipage.com/Swaps/engineswaps.html
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
