Author Topic: 16v manifold bolts - nightmare  (Read 889 times)
Offline Diluxe
« on: 21 April 2007, 20:02 »
one of mine manifold gaskets has gone, i got 7 out of the 8 copper nuts off, but the 8th that sits at the bottom 2nd in from the right if looking from the top, i cant get off for love nor money, i cant see the state of it because of where it is , a ratchet wont fit as there isnt any room, nor will a 12mm ring spanner b'cos the nut is rounded (i guess), has anyone please got some ideas on what i can do?
cheers
1997 16V
Re: 16v manifold bolts - nightmare
« Reply #1 on: 24 April 2007, 15:57 »
buy yourself a set of good molegrips, will make short work of it :)
If that fails a dremel will work, its tricky but eventually you'll get there!
Offline richard s
« Reply #2 on: 24 April 2007, 21:38 »
HAVE A LOOK ON EBAY IN THE TOOLS SECTION FOR IRWIN TOOLS THEY DO A SET OF WHAT LOOK LIKE SOCKETS THAT REMOVE ROUNDED AND RUSTED NUTS ETC THEY CAN BE USED WITH A RATCHET OR A SPANNER AND THEY DO WORK A TREAT
« Reply #3 on: 25 April 2007, 11:27 »
rich they wont be any good on the nut he speaks of, its the one which is right under the downpipe so can only be accessed by a ring spanner!
Offline richard s
« Reply #4 on: 26 April 2007, 20:54 »
you can get a ring spanner on them but it just depends if you get enough clearance
« Reply #5 on: 26 April 2007, 21:23 »
theres hardly any, right pain in the arse!
