Author Topic: My engine sounds horrible  (Read 722 times)
giffy1988
« on: 18 April 2007, 15:54 »
hi all im new but im after sum advice  :smiley: iv got a mk3 GTI and there are a couple of noises im it worryed about. the tappets are quite loud and there is a squeek from the cam belt area. also wen i put my foot down these noises get louder n sounds like a deisel :cry: has anybody got any ideas on wot could be wrong and how 2 fix it?
also want to try restore the performance as i can only get 110mph and not a very fast 0-60
Offline theruler
Re: My engine sounds horrible
« Reply #1 on: 21 April 2007, 18:47 »
doesn't sound good mate
obviously you have enough oil in there ;)
worn bottom end causes rattles and effects the whole engine.
it sounds like the beginning of the end for your motor, from your description
get a new engine on standby, and dig a grave for your existing one
if you cane the engine it will make it expire sooner. drive it carefully until you have a replacement sorted.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 21 April 2007, 19:46 »
Possible its on its way out but before you worry to much about a new engine theres a few other things it could be.
A squeak from the cam belt area could be a few things, Worn water pump bearings spring to mind, are you sure its not from the aux drive belt? try to get a bit of WD40 in behind the pulleys be carefull to avoid the cam belt, see if that gets rid of it.
As for the tappets, they use hydraulic lifters which can knock very heavily sometimes, they will get louder when you apply a load to the engine. If they are knocking try an oil change and flush first then put in new oil with a bottle of wynns hydraulic lifter treatment, that will help cure your tappity tappits. if it comes back or doesnt help you will need a new set of lifters (£25 on ebay)
As for the performance issue, that could be something quite simple, or mabey not so simple, If your Lifters a very badly damaged it will fail to open the valves correctly which in turn will effect the performance.  My 1.4L golf has a very very bad lifter and indeed sounds like a diesel all the time but i know its the lifter and im not to worried about it.
Give those things a go, just out of chance it might cause the problems. Lifters can be an issue on the golf so once they are sorted you should find she runs allot quiter and smoother.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
