The garage
Help Needed!!!
Topic: Help Needed!!! (Read 2457 times)
Jonni B
Help Needed!!!
03 February 2004, 10:11 »
I've got a problem with my beloved MK1, wen eva i take a long sweeping right hand bend, there is a rubbing sound!! Any ideas? :'(
Gambit
Forum addict
Re:Help Needed!!!
03 February 2004, 11:32 »
rubbing sound coming from where?
Jonni B
Re:Help Needed!!!
03 February 2004, 11:44 »
sounds like its coming from the front right wheel
Blue MK2
Guest
Re:Help Needed!!!
03 February 2004, 11:46 »
does it do this on the left side? sounds to me like the inner tire is rubbing.
Jonni B
Re:Help Needed!!!
03 February 2004, 11:52 »
no its just on the right hand side
Gambit
Forum addict
Re:Help Needed!!!
03 February 2004, 13:08 »
turn the wheel on full lock and have a look around it
Jonni B
Re:Help Needed!!!
Reply #6 on:
03 February 2004, 16:43 »
will do! take it i'm looking for tyre ware!
AdamB
The Perfect Storm
Re:Help Needed!!!
Reply #7 on:
03 February 2004, 17:56 »
Are you running a large wheel/tyre combo? if so it could be the tyre rubbing the arch as the suspension compresses.
I don't own this anymore - I just can't be arsed to change the picture
lowgolf
Here all the time
Re:Help Needed!!!
Reply #8 on:
03 February 2004, 18:00 »
Or it could be that your front wheel bearing is on its way out
Last Edit: 03 February 2004, 18:00 by lowgolf
<br /><br />Yeah!!!
modulater
Re:Help Needed!!!
Reply #9 on:
03 February 2004, 22:30 »
sounds like either wheel bearing or Cv joint.
I would check how much pad thickness you have left as first as you can get a slightly sticking caliper.
If thats ok then jack the car up on the side its rumbling and spin the wheel to listen and check for any tight spots in the bearing. Now hold the wheel at half past twelve and try to rock it. feel for knocking. To confirm it is a bearing also rock it using your hands on the wheel at the quarter past nine position.
If you don't feel any play and its all sweet then start looking at your cv joint.
The garage
Help Needed!!!
