Author Topic: I found the secret oil temp, but....  (Read 8816 times)
Offline Teutonic_Tamer
Re: I found the secret oil temp, but....
« Reply #10 on: 08 June 2007, 12:21 »
I don't think that they are all meaningful to the layman - must be used by VW bods to check stuff.
Ok, thanks, maybe TT has a bit of info on them?
Sadly, no - I only know what is on the list, and some of them arn't confirmed.
Like you, I do have my suspicions that turbo boost (requested and actual), induction air temperature, pre and post cat lambda readings, and a whole host of other things can be read.
Maybe someone with VAG-COM can do some data logging.  :nerd:
I feel like a homo
Offline skylark
« Reply #11 on: 08 June 2007, 14:58 »
This info has made my afternoon :smiley:. Knowing the oil temp is very useful, something I think should be standard on any performace cars.
I never start to open the car up until the oil is up to temp.
Pity it can't be displayed in the centre console instead of average speed.
Offline wantmygti
« Reply #12 on: 08 June 2007, 15:24 »
I agree, but you'll soon find that the digital one isn't very good at all. It's certainly not accurate - it will read 95 degrees after a days rest, say if you drive to work then drive home. Fine on the way in, crap going home.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
« Reply #13 on: 08 June 2007, 16:01 »
Sommat like this:  :wink:
I feel like a homo
Offline TagnuT
  • Edition 30
« Reply #14 on: 08 June 2007, 19:34 »
Mmmmm....that would be nice.....
« Last Edit: 13 June 2007, 18:39 by TagnuT »
Bye Bye Edition 30
Offline TagnuT
  • Edition 30
« Reply #15 on: 08 June 2007, 19:35 »
« Last Edit: 13 June 2007, 18:40 by TagnuT »
Bye Bye Edition 30
Offline datracer99
« Reply #16 on: 13 June 2007, 09:05 »
yes, finally worked out mine aswell, have the same question as to what are the other numbers mean, and also as does Nicks GTi (wantmygti) reading 95 degress from cold start, and reading between 77-80 degrees warm running. strange :undecided:
I've seen something like this before on a race engine. The temp sensor for the EFI system was in the head, so what happened was that when the engine starts, for the 1st few minutes the water in the head gets hot, and goes very slowly through the cooling system, through the little bypass hole in the thermostat, as the thermostat is closed.
So the head gets to 95 deg quite quickly. Then as the thermostat gets some heat to it it opens, and lets cooled water circulate properly, so the temp in the head actually drops. Strange, but true.
On a race engine this was a pain for tuning, so we moved the thermostat to the other side of the engine, but on road cars it was never a problem.
I haven't had a look at the GTI motor to work out where the thermostat is, but if it's on the top radiator hose then probably it's the same thing happening here.
Offline Stiggy
« Reply #17 on: 13 June 2007, 11:41 »
I wonder if i am misunderstanding this secret oil temp thingy - it appears when you press "up" and "econ" on the dash, doesn't it?  Thing is, i only get one reading - how do you guys get a list of readings?  Also, my oil temp readings are well strange - sometimes its reading "50" after driving the car for about an hour! :undecided:  couple of days back it was 0 before switching the engine off.  Bit like a yoyo.  Car runs absolutely fine though.  This didn't happen before the oil change though - it was consistently reading 95.  Any thoughts? Am i doing something wrong? Is the car ok? Is the world round :laugh:?
ED30 gti 5dr pearlescent black with DSG, xenons, bluetooth, tinted windows, ipod, rear parking sensors, highline....and a huge grin!
Offline Hully
  • GTI Edition 30, Reflex Silver - May 07
« Reply #18 on: 13 June 2007, 11:55 »
The left hand temp dial alters the main digits and the fan speed dial changes the figures to decimals. Sorry can't help with the rest.  :sad:
MkIV GTI PD150 sold, now FOR SALE MkV GTI Ed30, Reflex Silver, 07, manual, 5 Dr, 29.5k miles, 1 owner from new, xenons, cruise, park sensors, ugraded VW stereo and sound system, MFSW, Armrest, sunroof, immaculate never raced or thrashed, totally original, For Sale - PM me for details.
Offline Simonet
  • Pearl Black GTI ED30
« Reply #19 on: 13 June 2007, 12:08 »
are you turning the middle dial to read "15" in the left hand window?? then the oil temp is displayed in the right hand window?
