Author Topic: ABS light  (Read 2787 times)
Offline adyh
Re: ABS light
« Reply #10 on: 02 April 2007, 14:17 »
Where do you live ? Im in london , but someone with it may be near you .
Offline Camboose
Re: ABS light
« Reply #11 on: 02 April 2007, 14:22 »
I live in Worcester. Would be great if someone nearby could help me.
Offline Stuad70
Re: ABS light
« Reply #12 on: 03 April 2007, 14:13 »
I have similar worries and did consider the question you poised but TBH I think my safety and the safety of others would suggest replacement / cleaning. The sensors are around £60 I think. For the diagnostics I would pop over to yell.com and search for Garage Services in your area and get on the phone. Mines OSR. A "how to clean the ABS sensors" with pictures would be very much appreciated as would prefer to try this tack first..
Anyone done this ? A lot of my local garages have suggested the sensor "may" just be dirty..
Offline boneybradley
  • Back in a Mk3...
Re: ABS light
« Reply #13 on: 03 April 2007, 14:16 »
Why not buy a fault code reader instead of going to a garage as you can buy the reader for about £30 and this will come in handy for the future
Offline adyh
Re: ABS light
« Reply #14 on: 03 April 2007, 14:20 »
They definately pay for themselves .
Offline Camboose
Re: ABS light
« Reply #15 on: 03 April 2007, 18:09 »
Where would I get a reader from? Are the shareware ones on ebay good enough to tell me which sensor it is? How hard would it be to test the sensors with a voltmeter??
« Last Edit: 03 April 2007, 18:20 by Camboose »
Offline monkeyalan
Re: ABS light
« Reply #16 on: 03 April 2007, 18:40 »
you can test them with a voltmeter.
theres a post somewhere telling you what the resistance should be. the fronts can be tested using the connector on the  strut and the rears are under the back seat.
Offline Camboose
ABS light
« Reply #17 on: 03 April 2007, 19:29 »
Can you explain exactly how to test? Do you know what the resistances should be? Is it easy to loacte the connectors? Cheers
Offline monkeyalan
Re: ABS light
« Reply #18 on: 03 April 2007, 20:57 »
