Author Topic: Over fuelling  (Read 1887 times)
Offline EvilScotsman
Re: Over fuelling
« Reply #10 on: 23 March 2007, 16:48 »
if its got a 9 pin serial plug on the other end its a vag com, if its a usb on the other end its a vag usb. Theres a manual for download on ross-tech.com and info on what cable works with what program  :cool:
The mk3 only uses 4 pins on the obd as its only obd1 but some very late vr6's are obd2.
Most important stuff works but the system is limited.
"Handheld OBDII Scanner"
Offline Mboy
Re: Over fuelling
« Reply #11 on: 23 March 2007, 17:32 »
Cannot start to run vag com because on the port setup i get error message  port status:ok, interface:not found  , any ideas ?
Re: Over fuelling
« Reply #12 on: 25 March 2007, 00:11 »
is it usb? and what OS are you using?
The drivers have to be installed manually for usb. Instructions are on ross-tech's site
