Author Topic: Does this sound like WUR to you??  (Read 2677 times)
Offline Dub-77
  • Dub again MK1 Golf Project
« on: 11 March 2007, 18:51 »
Hi got yet more probs with my 1990 1800 16v. After fitting a new dizzy, coil, plugs, cap, rota arm, ignition module, cleaning out the throttle body, cleaning out the isv, cleaning the earths, checking all the vacumes, checking for air leaks setting up the timing by the flywheel marks I finally got the old girl running sweet no misfires untill yesterday when i started it up was running for say 30secs then it started running rough revs dropping down it would rev up freely but idle was rough and if i tryed to drive it the throttle was so sensitive it was almost stalling.
This will last untill the car reaches a warm temp then it would be fine drives ok. So i turned it off left it for 3 hours and tryed it again started on the button ran for 20-30 secs then started playin about again same as before....
Does this sound like WUR to you guys????
Darren
Show me a man with a tattoo and i'll show you a man with an interesting past :wink:
Offline rowlers
  • I'm back - MK7 GTI
Re: Does this sound like WUR to you??
« Reply #1 on: 11 March 2007, 21:39 »
get a fuel pressure guage and test it - you can then do the wur mod as well and gain a few horses!!!
There are a couple of wurs on ebay at the mo!
Offline Dub-77
« Reply #2 on: 11 March 2007, 22:38 »
Lee just bought 1 £22????
Darren
Offline rowlers
« Reply #3 on: 12 March 2007, 17:45 »
let us know how you get on!
where did you get guage from? Also how do you intend connecting it up?
pics would be good!
sacvwgolf
« Reply #4 on: 12 March 2007, 18:12 »
whats wur
Offline rowlers
« Reply #5 on: 12 March 2007, 18:17 »
warm up regulator, do a search loads of stuff about it!
Offline Dub-77
« Reply #6 on: 12 March 2007, 19:38 »
Lee that was a WUR for £22 not a gauge I have got to do some more reserch on how to do the mod/ set up properly.
I tell u Lee this car is starting to get on me nerves  :undecided: its 1 thing after another.......
If you know any good links to the setup feel free mate...
Darren
Offline rowlers
« Reply #7 on: 12 March 2007, 20:07 »
WUR mod how to in maint' section :wink:
http://www.users.bigpond.com/INTERJECT/KSITEPLN.HTM#Why%20is, if you haven't seen already.
I think you need to measure the system pressure, to make sure the fuel pump etc.. is in good health, then set the control pressure with the allen screw in the back of the wur.
Offline Dub-77
« Reply #8 on: 13 March 2007, 15:30 »
Or maybe the thermotime sensor????
I've read that this sensor controls the cold start and the WUR is this correct???
As I said the problem is not the starting at the moment its about 30secs after its fired up then it really seems to misfire and virtualy imposible to drive then 5-7 mins later bang its fine????
Darren
Offline rowlers
« Reply #9 on: 13 March 2007, 16:57 »
thermotime possibly - i think this measure engine temp and initiates cold start/running procedures...?
like cold start injector, for a few seconds, I think the WUR looks after itself, as it heats up from its own heater and engine heat soak it naturally increases the fuel pressure to normal operating pressure - pressure is lower at cold start.
there is also the oil temp sender going to the ECU, not sure what this does (other than tell ecu how hot the oil is :grin: :grin:)
where is RJ when you need answers eh :grin: :grin: :grin: :grin:
