Golf mk1
Golf mk1 gallery
toofunkyhouse - mk1 gti
4
Topic: toofunkyhouse - mk1 gti (Read 49715 times)
BobbyT
Housemusic aint for everybody,only the sexy people
Re: toofunkyhouse - mk1 gti
Reply #10 on:
21 April 2007, 15:22 »
Well my mk1 is not running right at the mo, went to no rice and a couple of days later it started to cut out as if it was running out of fuel, this was bad as i was hoping to get to the GTI spring festival on the sunday. I had the fuel pump changed as i thought this might be on the way out but to no avail so i had to miss the show! Most of the garages around my area i really dont trust my mk1 to, they dont really understand the k-jet system so i managed to find a place in Witney that had all the right test equipment to check and set up the system propley! gave the car a good wash and polish and also wax oiled some of the underside and in the rear pannels and doors!
car on tow truck off to get fixed! (i hope!!!!!)
and on another note, i managed to get the oil temp and preshure vdo guages i have been after for ages to go with the vaults one already in the car! got them both for 20 quid with the bulb holders! so when i get the car back i can bang them in, have read up on it and it seems quite easy! also got some more blue led bulbs to fit in to them!
will let you know what was up with the car when they start work on monday!
BobbyT
Reply #11 on:
24 April 2007, 20:45 »
new speakers came today, getting a mate to make some mdf speaker rings to mount them on, going to fit them where the old one's go! lets hope they sound better than the 6 be 4's!
BobbyT
Reply #12 on:
01 May 2007, 20:38 »
here are the speaker rings my mate has made, just have to spray them up and get them fitted in the doors, will get some pics once i get my car back!
BobbyT
Reply #13 on:
10 May 2007, 14:24 »
well as the car is STILL at the garage i have been buying some more 'gubbins'
should look better than the standard one's!
BobbyT
Reply #14 on:
17 May 2007, 12:29 »
right now i have the car back i have started to fit a few bits and bobs, first up is this single wiper! also had a mk2 motor but i couldnt get it to work so have used the mk1 but tbh after a really good wd-ing it works fine!
BobbyT
Reply #15 on:
19 May 2007, 16:01 »
today i fitted some 5mm wheel spacers to the rear of the car to fill the arch out a little!
BobbyT
Reply #16 on:
25 May 2007, 14:51 »
Hi all, well the car now has a new hart beating in her! well kind of, i have bought and had fitted ( by paul who is a top bloke aka tomo38 off of here) a modded DX lump, its had head work and cam as well as a rebuild! Paul was a star and it took a little longer than expected to fit due to a few snags which paul sorted out! Now its all in the car really does go like stink! the fun factor is back big time!
here are a few pics!
Last Edit: 26 May 2007, 08:42 by Toofunkyhouse
BobbyT
Reply #17 on:
06 June 2007, 08:04 »
Hi all, well have done a few more bits and bobs - VDO's are in, just need to get the oil preshure working, also fitted the new speakers and window winders! Gave the car a good clean inside too! Took a few pics at my work too! ooohhh planes! lol
BobbyT
Reply #18 on:
07 June 2007, 12:05 »
here are some shots of the vdo's at night
grrr this is what happens when you have pulled a 14 hour night shift!
BobbyT
Reply #19 on:
11 June 2007, 08:51 »
a few pics of the car a bristol volksfest, another tan-tastic day!
4
Golf mk1
Golf mk1 gallery
