Author Topic: Too busy driving?  (Read 12201 times)
Phil mcavity
Re: Too busy driving?
« Reply #30 on: 07 March 2007, 10:46 »
TT, whats your reconing on Bridgestones, as my wagon is rapped in those, it wont be long before front will need doing so , are they any good, or can i buy better for less dosh?
Offline Ollieb7
  • B7 RS4 & 65 split,
« Reply #31 on: 07 March 2007, 12:09 »
Cheers Ollie - think i'll give it a try. Do you have any pics? How about tips? Is it easy to cut to size? Did you get the bonnet or bumper kit, or both? Sorry for the stack of questions!
Not much point for the pics - you won't see it. I'm afraid i won't have time for any pics as im away on buisness soon for a couple of weeks (car left in the wifes hands -eek  :cry:). I bought the bonnet kit. The left over is enough for the back bumper lip at the tail gate (got a dog!) and the rest (almost) for the lower sections of the from bumper. With the bumper kit you need to get as well for that bit extra but also because it comes with the rubber block used to get the water out - you need a plant spray to wet the bonnet first, apply the (cut to shape) film, move into position and spend a good bit of time getting the water out - leave a lip at the front to fold over the leading edge of the bonnet. This lip you will find collects alot of the water from removal of water so a leather comes in handy here - you could leave it for a while to dry and folder at a later time. This 'lip' process follows for the head lamp scoosher area. You should apply the film as a whole over the area and then CAREFULLY use a very sharp blade to cut to shape.
Not hard - Just need patience!
Offline wantmygti
« Reply #32 on: 07 March 2007, 12:11 »
Cheers Ollie, how much overlap do you tuck in the edges? Or is it cut to size as closely as possible?
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Ollieb7
« Reply #33 on: 07 March 2007, 13:03 »
About 0.5 cm will do - enough to meet the panel join under the bonnet - forgot - 1 more tip - For the front of the car cut the film so it follows the line of the body work creases - this helps to cover up the joins.
Offline wantmygti
« Reply #34 on: 07 March 2007, 13:07 »
Thanks. Will give it a go. Isn't it a pain top fold under the leading edge of the bonnet where it is cut out around the VW logo?
Offline Ollieb7
« Reply #35 on: 07 March 2007, 13:20 »
Apply the film with masking tape - and then use a pen - remove and then use sissors to cut. Remember if it all goes tits up you can use a hair drier to remove the film.
Best of Luck!
Offline wantmygti
« Reply #36 on: 08 March 2007, 22:09 »
ollie - have sent you a pm on this!
Offline Teutonic_Tamer
« Reply #37 on: 09 March 2007, 15:25 »
For me, price isn't an issue, the quality of tyre is THE most important issue.
Now IIRC you have RE050 ??? = pants, I actually think the Dunlop SportMaxx to be better, so that must really say somthing about those Bridgestones!  The only Bridgestone I ever liked was the S-03 Pole Position, but they are difficult to get hold of.
I've listed my own recomendations elsewhere in this thread.
Another nugget of info - even Goodyear have now seen the light with directionals, and now have an assymetric high performance tyre!
Linky: http://eu.goodyear.com/uk_en/tires/repository/Eagle_F1AS/index.jsp
I feel like a homo
Offline Simonet
  • Pearl Black GTI ED30
« Reply #38 on: 09 March 2007, 22:58 »
5000 rpm today (kind of had to get in front quick on a roundabout) and it don't half go!
