Author Topic: Am I mad?  (Read 3606 times)
Offline vw-bob
Re: Am I mad?
« Reply #10 on: 02 March 2007, 17:07 »
i live in the south east and have filled up my car at both morrisons and tesco in the last week or so and have felt no problems. i have been filling up with the good stuff as i thought it was only the 95 octane that was affected
Offline mk2mark
Re: Am I mad?
« Reply #11 on: 02 March 2007, 17:30 »
Whoa this is a bit of a can of worms. I can't remember where I saw it, but apparently over there the quality of tesco's premium stuff is second only to optimax :huh: I'll try and find out where I saw it, most petrol comes from the same place anyway.
Offline mk2mark
Re: Am I mad?
« Reply #12 on: 02 March 2007, 17:37 »
Offline Uruk Hai
Re: Am I mad?
« Reply #13 on: 02 March 2007, 19:10 »
Apparently its mostly affecting cars with a lambda or oxygen sensor  :undecided:
Offline mk2mark
Re: Am I mad?
« Reply #14 on: 02 March 2007, 19:26 »
Yeah, higher octane's not much use if your engine's not aware of it somehow. not that an oxygen sensor does that :huh:
Offline ...joe
Re: Am I mad?
« Reply #15 on: 02 March 2007, 21:26 »
well martz as g60's have a lambda probe i'd keep topping it up with nicer stuff!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Neaty
Re: Am I mad?
« Reply #16 on: 03 March 2007, 00:54 »
I have never understood what these lamda dooers do, what are they?
Offline Martz
Re: Am I mad?
« Reply #17 on: 03 March 2007, 01:36 »
I have no idea? Oxygen sensors?
Offline Neaty
Re: Am I mad?
« Reply #18 on: 03 March 2007, 01:49 »
again, i have no idea  :undecided:
Offline Agreeable Slick
  • Unit
Re: Am I mad?
« Reply #19 on: 03 March 2007, 02:20 »
Lambda sensors boys and girls.
The are fitted to the manifolds of cars, and measure the concentration of oxygen remaining in the exhaust gases when they are released from the cylinder head. The sensor then sends this info to the ecu of the car which then decides if it is running too rich or too lean and then adjusts the fuel/air mix accordingly. Oh and all digis have them afaik, so it's not that newer technology.
Damage to these, can not only cause damage to the car engine by giving false readings but can also cause your catalytic convertor to fail. So lets say a lambda probe is about £40, and a cat is say £230ish, then there is fitting, which can be say 2 hours to remove all the manifold and surrounding gubbins, you are looking at about £350 for repairs.
Drop in the ocean then.
