Author Topic: ECU - where is it?  (Read 3162 times)
Offline Len
Re: ECU - where is it?
« Reply #10 on: 26 February 2007, 20:12 »
Also for ECU related issues in the Deals & Discounts section there is a place offering 5% discount on testing.
www.sas.org.uk
www.the-ace.org.uk
Offline 8vgti
« Reply #11 on: 27 February 2007, 22:13 »
Well VW have managed to get my car running and supposedly all they have done is to change the ecu relay.....unbelievably annoying as this is the first thing I tried before resorting to the garage as that has gone before. Whats the chance of buying a new faulty relay?????
The previous garage tried everything with no luck so will find out tomorrow if this works...if it does it is the most expensive relay ever.
Offline Len
« Reply #12 on: 28 February 2007, 09:09 »
Well I spent nearly £300 before finding out it was the relay! How much did you spend?
Any other advance on 300?
 :laugh:
www.sas.org.uk
www.the-ace.org.uk
Offline 8vgti
« Reply #13 on: 28 February 2007, 11:11 »
so far Len the cost has been £150 (£100 for the garage and 50 for dizzy cap, leads) and the £8 for what might be a faulty relay! VW have phoned this morning and the car starts but they havent driven it which was what happened last time and it played up.
If it is the relay I will well p*ssed off as that was the first thing I changed....oh well at least it will be running. I reckon the bill from VW will be at least £150, so I may come close to your 300!!!
will keep you posted
Offline Len
« Reply #14 on: 28 February 2007, 11:17 »
Not heard of a faulty ECU relay preventing the car starting before so yea let us know.
www.sas.org.uk
www.the-ace.org.uk
Offline patch900
« Reply #15 on: 28 February 2007, 12:26 »
 :laugh:
Thanks to everyone on here when mine played up it only cost me the ECU temp relay  :grin:
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
Offline 8vgti
« Reply #16 on: 28 February 2007, 13:05 »
Len, several years ago I had an itermittitent problem where the car would cut out and then eventually the car just wouldnt start, it would just turn over - the cure for this was to replace the ecu relay so it is similar syptoms this time - just that the ecu relay made no difference this time when i replaced it.
still no word from VW so I think that the test drive showed up the problem
Offline patch900
« Reply #17 on: 28 February 2007, 15:16 »
Hall sender, relay 30 ???
Offline 8vgti
« Reply #18 on: 01 March 2007, 09:25 »
changed it but made no difference.
Well got car back from VW and it was the fuel pump relay......which I had bought and tried before taking it to the garage so not happy that it could be a faulty one I bought  :angry: :angry:
Grand total for two garages to sort the problem £272.00, plus the £40 I spent on leads and dizzy cap  :cry:
Going to try the relay I bought again at the weekend to check that it is faulty and is not just an intermittent fault elsewhere that may have cured itself temporarily. Not totally sorted cos now if you take the car over 5000 rpm it feels like it has hit the rev limiter....will have a search on here cos I remember a similar thread a while ago. Why is it these costs occur just as you are looking to sell your motor??
Offline patch900
« Reply #19 on: 01 March 2007, 09:31 »
8v, if its hitting the limiter at 5000rpm its very likely its the timing belt thats out. Could be other things but in most threads this is the cause.
The same thing happened on mine. Timing was out, running lumpy and revving to 5000. After adjusting all has been fine.
