Cosmetic and bodywork matters
Can you change wheel offset and PCD
Topic: Can you change wheel offset and PCD (Read 1743 times)
patch900
Here all the time
21 February 2007, 19:04 »
Anyone know if you can change wheel offset ? I cant remember what the normal one for a golf is BTW.
I would expect you can get adapters so you can change the PCD, am I right ?
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
...joe
Forum Supporter
Forum addict
Re: Can you change wheel offset and PCD
22 February 2007, 10:04 »
you can change the pcd by using adaptors and that will also lower the offset. a spacer will lower the offset but you can't make it higher.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
patch900
Here all the time
22 February 2007, 10:19 »
Cheers Joe, lovely car BTW
...joe
Forum Supporter
Forum addict
22 February 2007, 23:29 »
cheers!
mase
Here all the time
mk3 madness!!!
02 March 2007, 10:57 »
depending on the wheel design of course, couldnt you have a few mm skimmed off the internal mounting face of the wheel to increase the offset slightly?
Quote from: Slick#13
I still see there is a distinct lack of b!tch tit getting outage.
...word
