Author Topic: Mk3 Engine Speed Sensor - Car cuts out !  (Read 5451 times)
Offline phulla
Re:Mk3 Engine Speed Sensor - Car cuts out !
« Reply #10 on: 06 May 2004, 11:05 »
I've been having this intermittent cutting out.
I have changed the ECU relay and it still happens.
Now its a lottery to see which part to change. I have had it diagnosed and nothing was reported faulty...
I have checked the leads at the ignition switch, with the car running i moved the cables and plug around as much as i could, but all was fine. i unplugged it and plugged it back in, but the fault did not occur.
Now which of the following do i change?
Coil/Transformer
Speed Sensor
Ignition Switch
Dizzy/Hall Sender
Did Black_GTI ever find out which sensor was changed when he bought his car?
AS everyone case is urgent, mine is severly urgent, as last time it cut out, i was nearly collected by a few cars travelling along a dual carriageway at 40mph+, i had my wife and 2 year old son with me!!!
Offline phulla
« Reply #11 on: 08 May 2004, 01:22 »
BUMP!
