Golf mk2
ECU Advice
Topic: ECU Advice (Read 677 times)
Harvemk2
ECU Advice
07 February 2007, 20:44 »
My engine just died on me the other week!
After having an auto electrician do some tests he said everything pointed towards the ECU. Does anyone know whether you should just be able to plug the new 1 in or does it need tuning/programming somehow??
Thanks in advance.
cняis
Know there's something burning over there...
Re: ECU Advice
07 February 2007, 21:09 »
wont need reprogramming, just a another compatible unit, eg. if yours is an 8v digi, get another ecu from a digi. also, there were different manufacturers of those ECUs, i.e. Bosch/Tan and so get the corresponding one.
Quote from: oilman on 19 November 2010, 14:24
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: ECU Advice
08 February 2007, 12:21 »
what are the symptoms, the first thing you should do if you suspect a dead ECU, is to remove all the battery/starter/alternator wires, and give the connections a good clean with sandpaper till they're shiny. Especially the gearbox earth, as a loose/poor gearbox earth will cause the ECU to blow. You don't want the new one to blow as well do you?
Golf mk2
ECU Advice
