Author Topic: fix those clocks !!!!!!!!!!!  (Read 7824 times)
Offline daros
Re:fix those clocks !!!!!!!!!!!
« Reply #10 on: 05 February 2004, 17:40 »
We need an electronics expert?
So many people have posted with the same problem - broken MFA/rev counter.
The traditional remedy being replacing clocks or shelling out ?140 to fix the old ones..
Even the name/address/tel. no where this can be done for 140 quid would be appreciated.
David
SOMEBODY........ANYBODY........PLEASE!!!!!!!!!
Come on guys......please dont let me down.....this is starting to remove the pleasure from driving my GTi and replacing it with sheer frustration!! lol
Offline reserves
« Reply #11 on: 06 February 2004, 03:50 »
Try searching for a company called Digidash.
It's alot cheaper to try to find a 2nd hand pair of clocks though.
R
Offline Gambit
« Reply #12 on: 06 February 2004, 09:21 »
there is a small voltage regulator on the back of the clocks that sometimes fails, this just pushes into the back of the clocks and costs about ?7 to replace
Can this be bought separately? If so, from where?
VAG stock them
« Last Edit: 06 February 2004, 09:21 by Gambit »
Offline pc16v
« Reply #13 on: 06 February 2004, 18:34 »
it may be a long shot but when i had a beemer, my clocks stopped working . i found a company in ether performance bmw, or whatever the sister mag to the golf is called,who i sent the whole unit to and got them back for  ?50. all in.so if you can get your hands on a copy,look in the back an you might be in luck .
Offline hazlington
« Reply #14 on: 12 March 2004, 10:18 »
same problem h reg, motometer clocks, no rev counter or MFA,
bought an E reg for spares with motormeter clocks but it has two connectors & the h reg only has one, thought that if the wires would
match colour for colour I would swap the connectors but the E reg has
18 wires & the H reg has 21. The clocks are identical except the temp
light on the E reg is in the temp gauge & on the H reg it is in the row
of idiot lights, cannot figure what the extra 3 wires are for.
going to try swapping any way will post the result.
Blue MK2
« Reply #15 on: 12 March 2004, 10:59 »
anyone got a broken spare set of clocks?
Offline reserves
« Reply #16 on: 12 March 2004, 11:15 »
I just threw mine away after replacing them  :(
I do have a spare set of working ones, single 24 pin unit for post 90 golfs, showing 91,000 miles.
Easier than getting them fixed.
Also I realised that the water warning light doesn't work when the unit goes, I put my new unit in and realised I'd been running low on water, oops....
Blue MK2
« Reply #17 on: 12 March 2004, 11:21 »
damn! :(
ive worked for a few electrical, electronic places/contractors. I recon i could give it a good go at fixing some clocks. maybe even make a profit ;)
Offline Mk2Gti8v
« Reply #18 on: 12 March 2004, 12:11 »
VAG stock them
part number 171 919 803 for the regulator (7.40+VAT) and 193 998 089 for the heat sink
« Last Edit: 12 March 2004, 12:19 by Mk2Gti8v »
Offline Mk2Gti8v
« Reply #19 on: 15 March 2004, 11:09 »
Well spent saturday taking out the clocks and changing the voltage regulator (the regulator was easy to swap) and putting it all back together just to find out it didn't work! hay ho, new clocks must be the way forward way!
