Author Topic: Rear window washer  (Read 987 times)
Offline Mart8V
  • I really should know better by now.....
Rear window washer
« on: 03 February 2007, 18:12 »
Seems to be knackered.  Is the pump on the tank in the engine bay or somewhere else?  Is this a quick fix? Rear wiper motor works OK.
Offline rowlers
  • I'm back - MK7 GTI
Re: Rear window washer
« Reply #1 on: 03 February 2007, 18:34 »
give the washer hole a clean out, tend to get full of sh|t, clean it out with a pin and some WD40 or something, same pump as front washer jets (I think??) so if front are working then it will just be a blocked hole, or possibly the pipe in the boot has come off, but then you'd prob have a wet boot!
Offline Mart8V
« Reply #2 on: 03 February 2007, 19:41 »
Hole seemed clean, and no fluid in boot so may be blocked somewhere else.  Will check it out in the light!
Many thanks.
