Author Topic: Diagnostic port  (Read 1052 times)
Offline heinz
Diagnostic port
« on: 31 January 2007, 21:19 »
 Have just fitted a mk3 2.0 8v engine and wiring loom  I have the loom for diagnostic port but it only has 4 wires on two two pin plugs    not sure what diagnostic system it is as I thought obd2 had 5 wires? anyideas?
 Cheers Si
Offline systemseiko
Re: Diagnostic port
« Reply #1 on: 31 January 2007, 22:29 »
The old Mk 3 GTi's are OBD1 compliant but you need a different connector and Vag.com or simliar fault code reader,  you can purchase one from E-Bay for around £8.00 from china.
http://cgi.ebay.co.uk/2x2-Adapter-VW-Audi-Skoda-diagnostic-OBD2-KKL-OBD-VAG-2_W0QQitemZ220075978799QQihZ012QQcategoryZ30921QQrdZ1QQcmdZViewItem
Cheap as chips
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
