Author Topic: can anyone help  (Read 2099 times)
Offline chevychase
can anyone help
« on: 23 January 2004, 00:09 »
i have got a broken rubber tube, its small at one end and big at the other. it comes off the air box and goes into the engine by the oil filter. i've had a look in the haynes manual and theres not much help but they had a little pic and im not sure if is the right one. crankcase breather ring any bells?
89 golf gti 16v
golfvr6
Re:can anyone help
« Reply #1 on: 23 January 2004, 00:15 »
Yep it sounds like the crankcase breather hose.
Offline chevychase
Re:can anyone help
« Reply #2 on: 23 January 2004, 18:47 »
cheers golfvr6.
do you know where i can get one from?
Veedubgt18v
Re:can anyone help
« Reply #3 on: 23 January 2004, 20:07 »
vag or a scrappy if you can find a pipe in good nick. shouldnt think they would be that expensive
Offline chevychase
Re:can anyone help
« Reply #4 on: 23 January 2004, 21:39 »
are they only on 16v or can i find them on 8v to
Veedubgt18v
Re:can anyone help
« Reply #5 on: 23 January 2004, 23:36 »
they are on all golfs but they will prob be different shapes, sorry i dont know what a 16v one looks like  :(  get one and compare it to yours, i would go to vag tho they will give you the right one and it wont be rotted/fragile/oily etc
golfvr6
Re:can anyone help
« Reply #6 on: 24 January 2004, 00:57 »
I'm sure the 16v breather is different to the 8v.
Offline modulater
Re:can anyone help
« Reply #7 on: 24 January 2004, 14:01 »
The 16V breather is on the front of the block and the 8V one is mounted on the cam cover and has a big plastic plug that replaced the earlier built in wire mesh type cam covers.
Sounds to me like the breather to airbox hose.
Offline chevychase
Re:can anyone help
« Reply #8 on: 25 January 2004, 10:14 »
f*"king robbing ba"t*rds. 50 quid they wanted for a bit of rubber pipe. any  ideas
