Author Topic: **New Clocks - oil warning light coming on? HELP**  (Read 3750 times)
Offline G60Dan
  • 20VT baby!
Re: **New Clocks - oil warning light coming on? HELP**
« Reply #10 on: 29 January 2007, 13:30 »
2nd half
E
1 - gry/grn- number plate lights
2 - grn/blk- rear wiper motor pin 53
3 - red - interior light & boot light
5 - vio/blk- fuel pump or fuel gauge sender pin G
6 - blk/wht- left rear indicator
7 - grn/red- windscreen washer pump pin 31 (rear pump on earlier models)
\- brn/blu- windscreen washer pump
8 - blk/gry- rear wiper motor pin 53a
9 - grn/blk- left rear light
10- grn/wht- rear foglight
11- blk/grn- rear right indicator
12- blk - reverse lights pin RF
13- grn - handbrake warning switch
14- red/wht- warm up regulator, aux air regulator & control pressure regulator (K-Jet f/inj)
\- red/yel- main & transfer fuel pumps
15- wht-wht/grn- rear window heater and heated mirror glass
16- blk/red- brake lights pin 54
18- grn/red- rear light bulb
G
1 - blk/yel- Electric mirror adjustment switch pin 5 & electric window relay pin 6/86
2 - blk - heated washer jets, spare plug behind fusebox & idle stabilser valve pin 2/15
3 - blk/yel- heated seat control units pin 17/15
9 - gry/grn- headlight washer relay pin 5/56
10- grn/red- headlight washer relay pin 4/5
H
1 - red/wht- radiator fan thermoswitch & A/C refrig. high pressure switch
2 - red/blk- A/C switch
3 - red - Battery +ve
4 - grn/yel- A/C thermostat
5 - yel/red- fresh air fan switch pin 4
6 - blk - fresh air fan
K
5 - brn/red- ignition switch pin S or SU (difficult to make out!)
L
1 - blk/yel- fusebox pin A/25
2 - brn/blk- fusebox pin B/25
3 - brn - earth location 16 or 81
4 - brn/blu- horn switch
M
N - red/wht- inlet manifold heater
\- red/blk- f/injection relay pin 86 (K-Jet f/inj)
P - red - battery +, ignition switch pin 30, electric window relay pin 87, headlight washer relay pin B/30 & f/injection relay pin 30 (K-Jet f/inj)
R
1 - blk - fusebox pin D/2 (digifant f/inj)
2 - blk/yel- digifant ECU pin 14 & fuel injectors (digifant f/inj)
Offline G60Dan
  • 20VT baby!
« Reply #11 on: 30 January 2007, 07:35 »
probs sorted. I had to earth the yellow wire - high oil pressure
Thanks all
